Results 1 to 6 of 6
    Aug 2010
    Cannondale Rush Crank Replacement ??
    I just bought a used alloy Cannondale Rush and the right crank arm pedal threads are stripped out (which resulted in my getting a good deal on the bike).
    Not sure what year it is but the components are somewhat low-end and it's a stealth black color if that helps any...
    It currently has a FSA Alpha Drive (ISIS BB) which seems a bit low-end so I'm not sure it's a good idea to simply replace the arm.
    Any suggestions for an upgrade/replacement (preferably w/o replacing the BB but...)
    I'm new to the MTB scene but I've been riding C-dale on the road side for some time (currently riding a System6 & a Slice)
    Thanks in advance,
    Nick
    Aug 2010
    Okay, assuming that I replace the BB, can anyone tell me the 'spindle width' I should be looking for?
    It's a Rush 600 if that makes any difference.
    The manual just states - 68mm, English /SI Hollowgram
    I'm thinking that this one http://www.treefortbikes.com/cat/0/2...222364321___93 may work ?
    I'm open to other recommendations - I just want to get something ordered & installed so I can go out and ride!
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    The crankset you've linked to looks to be an external bearing crankset - not a splined one. If that's the case then it won't work with your existing bottom bracket. It looks as though it's supplied with the cups and bearings on it. If that is the case, then you'd remove your old bottom bracket and install these and the cups and bearings as a complete replacement package.
    Here's is FSA's page or these cranks:
    http://www.fullspeedahead.com/fly.as...=533&taxid=298
    On that page it says they come with a "steel Mega Exo bearing" so it looks like you get the cranks and the cups and bearings as a package. Those ones will fit your 68mm shell.
    I think you'll like your Rush - I love mine.
    Less isn't MOAR
    Nik, that crankset would work, but the best deal going right now is the closeout LX hollowtech crankset at Jenson. I just put one on my Rush 600 when I had to replace teh original ISIS bottom bracket. 85 dollars for crank and external BB was tough to beat.
    http://www.jensonusa.com/store/produ...+Crankset.aspx
    Aug 2010
    Thanks guys.
    I just ordered the Shimano Deore LX cranks and some pedals from Jenson - great find!
    That is a very sweet deal!
    Less isn't MOAR
