Results 1 to 11 of 11
    Jun 2010
    Cannondale Rize is this a crack?
    Is this a crack in the chain stay or just paint?
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Yep, it's a crack. Are you the original owner?
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Jun 2010
    No I am not.
    Jun 2010
    I know a really good welder, can this be reenforced?
    Jun 2010
    Talk to guy I got the frame from and knows original owner, so will see what happens.
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    it is 6061-T6 aluminum. It can be welded, but then you will have a very weak area around the weld called the Heat Affected Zone. If you decide to have it repaired, you will need to have it welded and then fully heat treated to bring it back up to T6 temper. This can be done. I did it with an old Jekyll over 2 years ago.
    I had mine done at a place called Industrial Heat Treating. Catchy name. The frame (or swing arm) needs to be stripped of all components and screws. Don't worry about the paint, it will all burn off. They heat it to 1,050 degrees which puts the aluminum alloy into a particular molecular structure that gives it great strength and then they quench it by dunking it into a tank of anti freeze. This locks the alloy in this state which is now T4 temper. It then needs to be baked at 400 degrees for 4 hours to bring it up to T6. If it is done right, it can be as good or in your case better than new. Good luck.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Jun 2010
    Thanks that excellent reply and resources. Hopefully the original owner has luck with Cannondale.
    Ridin' dirty!
    Or you simply buy a new swingarm before they don't have them in stock anymore.
    I have a 2010 RZ 140, does it have the same chain stay? Are all models of the RZ / Rize swing arms made of aluminum or do some have carbon?
    OP - Good luck with the warranty! good to know about the welding heat treating process!
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    Quote Originally Posted by paineman View Post
    A new and improved swingarm arrived w/ the switch the "RZ" name. It lacks the propensity to crack like the Rize swingarm. From what I've seen, it seems it is basically just a matter of when, not if, the Rize arm will fail.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    I have an old R300 Cannondale road bike with a crack on the chainstay that runs lengthwise. Is that bad? Can I still ride the bike?
  1. Cannondale Rize will it go 650b?
    By phantom_309 in forum 27.5
    Last Post: 05-26-2016, 07:48 AM
  2. Replies: 45
    Last Post: 01-26-2012, 09:17 AM
  3. 2009 Cannondale Rize
    By cimminob in forum All Mountain
    Last Post: 09-01-2011, 09:30 PM
  4. Shock question. Cannondale rize?
    By bao in forum Cannondale
    Last Post: 07-01-2011, 04:21 AM
  5. Cannondale Rize Seatpost diameter??
    By broom broom in forum Cannondale
    Last Post: 06-14-2011, 04:40 AM
