Results 1 to 2 of 2
    Oct 2011
    cannondale handlebar stem
    hey. the handlebars on my cannondale has a cap on top. no set screws or anything that i can remove to take the handlebar stem off and replace with a taller one. any suggestions. also. the size ( diameter of the stem on the bike now seems huge. i see most are an inch and 1/8th. but this looks bigger. it has the mono shock on it so i'm assuming that the stem isn't just screwed in as usual. its a threadless stem. the bike is a delta v 600. if that helps. thanks for any help i can get....
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    All you gotta do is loosen the hex bolt in the back to remove the stem.
    Attached Thumbnails Attached Thumbnails cannondale handlebar stem-%24-kgrhquokpie24rmek2obn2-dr4-t-%7E%7E_35.jpg
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
  1. recommend a good handlebar stem setup for a 6'4" cannondale rider
    By dairyman in forum Clydesdales/Tall Riders
    Last Post: 03-28-2011, 11:32 PM
  2. UGI Handlebar and stem?
    By yendis in forum Turner
    Last Post: 02-10-2009, 04:21 AM
  3. Help: Looking For Cannondale Handlebar
    By Richard Roma in forum Cannondale
    Last Post: 05-10-2008, 09:53 PM
  4. New Stem and handlebar help
    By G_Blanco in forum Beginner's Corner
    Last Post: 01-16-2008, 05:06 PM
  5. 25.4 vs 31.8 handlebar/stem
    By budgie in forum All Mountain
    Last Post: 05-26-2006, 11:37 PM
