Results 1 to 3 of 3
    Reputation: aplitt86's Avatar
    Cannondale 1fg 29er Build Questions
    My plan was to build a semi-light decent hard tail to race on next year for as little as possible. I got a screaming deal on a 1fg Caffeine 29er 3 frame a few months ago and am finally getting ready to build. The problem is I want to run gears. So I'm thinking about running 1x9 or 1x10 with a 34t chainring. Not a big deal, but the frame didn't come with an EBB. I already bought a der hanger. Now I'm stuck at what to do for crank/bb options.
    I wanted to run a BB30 crank but am having trouble finding an EBB that supports BB30. The only one I found is the Phil Wood HL30. Anyone have experience with this and if it will suit my needs? Other suggetions?
    I also plan to buy a lefty but not sure what to look for. I have read most of the lefty threads about reducing travel of a 26" lefty for the 29er. I'm fine with 80mm of travel. Just not sure the best lefty to look for. Don't want to spend more than 4 or 500 on ebay for one. Any suggestions for the lefty are appreciated as well.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    3 years ago i did my F29er
    i installed THM Clavicula external cups
    and a BB30 Carbon SI Cannondale crankset 2 x 9
    you can also install those cups ( Zipp cups are the same ) with an Hollowgram BB30 SL crankset
    but spindle must be machined to remove lip
    i installed a 110 reduced to 80mm carbon SL 2008 Lefty fork
    bike was 9.6 kg with a below 1700 euro cost ( not remember well but around this value )
    Thanks for the suggestions, but my F29 has an EBB shell. I was looking for a possible solution to buy an EBB adapter that is BB30 compatible so I don't have an EBB and then an External BB30 converter as well.
  1. Titus Racer X 29er build/questions
    By Daniil in forum 29er Bikes
    Last Post: 11-09-2011, 08:44 AM
  2. 29er build questions
    By BikeNE in forum 29er Bikes
    Last Post: 10-31-2010, 07:55 PM
  3. Replies: 3
    Last Post: 01-04-2010, 01:47 PM
  4. 29er build questions
    By harrisongladden in forum 29er Bikes
    Last Post: 10-19-2009, 03:27 PM
  5. Replies: 10
    Last Post: 10-08-2009, 04:14 PM
