Results 1 to 9 of 9
    Jun 2010
    Can I run 3x9 setup on 2011-2012 Scalpel?
    Can I put 3x9 setup on 2011-2012 Scalpel. Obviously there should be no problem with RD, shifters and BB30 cranks, but what about FD? I have XTR 970 with high clamp, but new scalpels use direct mount FDs... and it seems like seat tube is not exactly round?
    I would very much appreciate if someone could post some pics of real-life setups!
    Thanks for the answers ))
    You may be able to run a Shimano E-type derailleur. This mounts between the bottom bracket and the crankset. However, you will need a BB30 adapter because it requires a proper flange.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Shimano still make 3 ring setups and I sure hope they have Direct Mount front derailleurs. E-Type wont work with a BB30 crankset...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Jun 2010
    Quote Originally Posted by Dan Gerous View Post
    actually I could not find direct mount 3x9 FDs...
    What about with an adaptor that allowed you to run an Octalink BB?
    Reputation: nathanbal's Avatar
    what would stop you using your current front dee in a triple config? wouldnt the limiter be on the front shifter? cant be that hard to find a triple crank using bb30. the hollowgrams can be used as a triple.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    ehi guys stop having troubles !!
    Shimano with its Etype go one step beyond years ago.
    an E type can be "disassembled" : withouth the BB plate , it become a DM S3 derailleur
    the one we need for Scalpel mount.
    so remove the plate and the 2 bolts and install it .
    look it without plate
    FIRENZE rulez !!
    and look on board from Alex' bike
    mod XTR M970 E-Type FD - 18.08.09 #3435 v2 | Flickr - Photo Sharing!
    hurry up , stiil on pc ? go to work in garage on the bike
    Dec 2008
    and this shimano xt 9sp m771 direct mount? will work too correct? on a 3x9 system on a 2012 scalpel? i gotta found the correct fd too for this frame.
    the etype version is like this one?
    both versions will work on the 2012 scalpel?
  1. Epic 2012 same as 2011 ?
    By Devastazione in forum Specialized
    Last Post: 11-24-2011, 09:57 AM
  2. 2011 or 2012 Remedy 7?
    By mo6500 in forum Trek
    Last Post: 08-12-2011, 01:38 PM
  3. 2011 vs 2012
    By nzl62 in forum Ibis
    Last Post: 07-20-2011, 02:14 PM
  4. 2011-2012 syren?
    By Reign rider in forum Transition Bikes
    Last Post: 07-19-2011, 03:30 PM
  5. 2012 Scalpel 29er FS At Sea Otter
    By adkbiker1 in forum Cannondale
    Last Post: 04-19-2011, 10:56 AM
