    Can anyone measure their lefty for me please?
    Hi, I'm building up the wheels for my new Flash 29er Carbon build. I don't have a jig so I'm building it Ghetto Style (in the frame) The rear is fine, as I can check any offset against the chainstays. The front, however has nothing to check against! (bloody lefty! ha ha) I can only eyeball it against the downtube to see if it's centred / dished right.
    I wonder if someone would mind measuring the distance between the INSIDE of their lefty leg and the rim of the front wheel (the bit that would have been the braking surface if there were rim brakes) If you can tell me this distance and your rim make / model, then I should be able to work out how far the centre of my rim (Stans Crest) is from the lefty and get the dishing spot on.
    Many thanks if you can help!
    Jim
    Music & Bikes
    Reputation: fokof's Avatar
    "There is a big difference between kneeling down and bending over" -FZ
    Info from Cdalemaniac:
    -Disc side 14mm,
    - 20.4mm on the other.
    Thanks guys, that's really helpful
  1. How do you measure it?
    By outaluck in forum Clydesdales/Tall Riders
    Last Post: 01-11-2011, 04:11 PM
  2. where do I measure?
    By bgfthntr in forum Shocks and Suspension
    Last Post: 11-02-2009, 01:02 PM
  3. How do you measure BCD
    By Stonebreaker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-14-2009, 09:10 PM
  4. how to measure sag?
    By nosewheely in forum Downhill - Freeride
    Last Post: 11-06-2007, 11:36 AM
  5. Replies: 4
    Last Post: 03-01-2007, 08:15 AM
