Can't stop the Prophet
Most shops stock these things, no need to be a Cannondale dealer.
Most shops don't stock them. They are the sort of things shops wouldn't bother with unless someone ordered them. I got mine from a german site that stocks all things Cannondale. Probably a bit pricey if you're in the States though.
Have a look here. You could get a delivery to Greece easily.
Here's the link http://www.cannondale-parts.de/epage...inbike/Prophet
sticky velcro is a good solution, i used it on my Prophet, just cut some very small bits and push them in to the little slots then stick the opposite bit around the outer casing.
try using the soft half of the velcro on the cable as i found it formed around the cable outer better. give it a go, very cheap from any hardware shop.
If the lbs lost them then they should have to replace them.
I have been eyeing the inserts that are actual cable stops. Instead of those stupid split things that come oe. They are fit in the frame stop, but will catch the housing so that you could either run the nokon aluminum outer housing, or individual housings cut to length, instead of a whole length of housing. I had some pretty heavy cable rub, that went unnoticed, and wouldn't have been a problem if not for those bloody split cable guide things. Don't know where you would get them, but my lbs stocks c-dale, and has them in the little treasure trays in the shop.
Hey guys, I don't have a direct reseller source for European countries but Jagwire (www.jagwireusa.com) Has everything you're looking for. They do not sell direct, but you should be able to find a European reseller from their site.
http://www.jagwireusa.com/index.php/contactus
IMHO there's no substitute.
'Don't understand how c'dale can make such good frames, then be so derelict in providing necessary parts. I found out the frustrating way when I got a replacement frame and could not fit the 5mm housings to the oversized braze-ons which are 7 or 8mm diameter. c'dale frame did not come with any adapters. Only the downtube brazeon for the front derailleur cable is 5mm. After many online searches and phone calls, found out c'dale part number for 'top hat' stop to fit oversized brazeon is KF014. KF014 is for segmented housings and holds the 5mm end cap in place. For continuous single housings, part number is KF086. KF086 is for full length housings without end caps. Just like brows141 in Greece, I will have to wait many days and drive to an undesirable location to get a simple part that should have been included with the frame (which took over 4 weeks).
Most (good) bike shops have those guides in stock.
I think they do it so you can run full housing if you want to.
My Rize frame swap had about 8 of them attached to the frame in a bag. It also had 8 cable patch things (clear). It had the hydro guides too.
If your lbs does not have them, Treefortbikes.com has them
Lead by my Lefty............... right down the trail, no brakes.
now I also need those cable guides. Seems like no store has it, and ebay as well. Can somebody recommend where to get it (a store must have worldwide shipping).
Thanks ))
Dibbs_
not an option for me. They do not ship to Kazakhstan ))
if you like full length housing then Jagwire DCA072 guide should work (see http://www.jagwireusa.com/index.php/.../accessories/).
I did not try them myself but they look like what I have on my Rize.
bikeman.com sells them
 Originally Posted by alex_k
yes, they do, but guides are out of stock...
any more suggestions?
yeah i need them too...i even tried to contact jagwire...but got condescendingly minimal support by email ["Did you try your lbs?']..
"He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
I feel you pain my friend. Those damn cable guides can be a pain in the ass to find!
You may want to try this site:
http://bike-parts.at-cost.org/disc-b...cs-dca072.html
Let me know if you still have a problem sourcing them. I can try and get them from my local LBS and send them to you.
Hi, I ordered 5.5mm Jagwire inserts from bikeman.com (a set of 50psc!!!), but I did not get them yet. I will post here, when i'll have them.
Hope 5.5mm will fit Rize frame )))
maybe they just dont make these anymore....so i wonder do the frame builders design the frame with this product in mind...or do the part makers make these afterwards....anyway, my prophet and gemini both use these...the problem is i need like 10 for my gemini...maybe i can mcguyver these from a piece of just the right diameter tubing
yeah I need these damn things too. I just couldn't bring myself to buy a 50 pack when I don't need nearly that many. I just used frikkin tape.
How much does the 50-pack go for?? Maybe we could split em 50-50. I need enough to do 2 bikes now!!!!!
yeah, where did you guys find a place to buy them...let me get in on the deal
Group Buy!!!!!
Yes!!!! I got those cable inserts... now I have 50 pcs of them!!!
order from bikeman.com
Here you can order - for those who is still interested...
- You may not post replies
- You may not edit your posts
Forum Rules
