Results 1 to 8 of 8
    Cable guide, flash 29er
    Anyone else hate the plastic guide on the bottom of the bottom bracket? It squeaks and makes shifting horrible all around.
    Any alternative other then a full housing. Mabye i am just due for a new guide. Bike is a year and a half old.
    Reputation: thatdrewguy's Avatar
    Quote Originally Posted by machine4321 View Post
    When it squeaks I just shoot a bit of chain lube on the guide and it quiets down. Easy fix.
    I have tried that. It doesnt improve the shifting, just the squeak. The it gets caked with dirt where I ride.
    Mabye i can try some wax lube and see how it does.
    the guide couldn't have worn out surely, i have a 1999 f1000 with original guide on it. you could try a new cable, before slashing out on a guide. a cable with a ptfe coating might help, or...
    gore ride on sealed. got them on mine - i am without squeak!
    should nave mentioned new cables a month ago. I might try to make something out of derlin plastic
    it would be good to see what you come up with.
    good luck.
    OK most of my experiences with getting the squeak are from shifting the front derailleur, where the shifting is perfectly fine but I get the noise. I ride in dusty conditions mixed with some water so there's no mud being caked on the cables at all.
    Tried a different chain lube on te guide and it did improve the feel and the squeek. The guide is not worn down like i though.
    I also had to suirt a tiny bit of lube in the end that starts in the chainstay. Might need to shorten the housing a tad bit to lessen the angle that cable has to travel through.
    I will see how long it holds up.
  1. Replies: 12
    Last Post: 05-27-2015, 10:01 AM
  2. Replies: 1
    Last Post: 04-16-2013, 06:20 AM
  3. Cable Routing Guide
    By sneakyt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-01-2013, 11:05 AM
  4. 29er Throwdown: Flash Alloy vs. Flash Carbon
    By brentos in forum Cannondale
    Last Post: 09-16-2012, 11:36 AM
  5. Flash 29er Cable routing
    By sherpa2000 in forum Cannondale
    Last Post: 03-04-2012, 09:27 AM
