Results 1 to 3 of 3
    C-Dale Jekyll 600 questions.
    I have a 2003 Cannondale Jekyll. It came with the Lefty Jake fork with 105mm of travel. Well I've been starting to want a little more travel for my riding (120-130.. maybe 140) because this shock is pretty rough over stuff and the Jake is beginning to make less and less sense since I can't add travel to it. Well I've been thinking about getting a Recon or Tora. Now how would this make the bike? Would I be able to sell my lefty? And for how much? My final question that may mix things up is what if I went 650b in the front. Would this give the similar feeling of "travel" it would be cheeper but would I get that plushness that I want? Any help would be great. Thanks, Preston
    I've just switched from my 130mm Pace RC41's to some 140mm Rocksshoxx Revelations on my '04 Jekyll 600. It originally came with a 120mm manitou black and I've raised the stem height right up to echo the position of my Rocky Mountains to give me a nice high front end. I'm using an FSA ZR orbit 1.5 to 1 1/8" internal reducer headset to keep the front end low and it rides great.
    I think a fork upgrade alone will give you want you want - the difference between an 03 and '10 fork will be night and day.
    Rich
    If you buy a Recon or Tora, you'll also need a new wheel, headset and stem.
    Why not look for a newer long travel Lefty?
    The Jake is a very basic Lefty.
