Results 1 to 3 of 3
    Jun 2010
    Cīdale F6 CO2 frame
    Hi
    Iīm looking into a F6 frame. I was told that it would accept my old 80 mm fork, but I canīt find it anywhere with a stock 80 mm fork. Is the dealer pulling my leg or is it a ok advice?
    Looking forward to hear from you
    keeping it dirty
    Reputation: intoflatlines's Avatar
    Should be fine if the steerer is 1 1/8" (and you have the adapter headset) and it's long enough..
    Mar 2005
    If you have the right headset and the steer tube is long enough, really the only change will be that the geometry is slightly steeper with the 80 mm fork than stock (about one degree probably- 71 vs 70 deg head angle).
