Results 1 to 5 of 5
    Broken Lefty Bearing Retainer
    My Lefty was a bit gritty when compressed so I disassembled it tonight and discovered one of the bearing retainers is broken. Any idea where I could purchase a new one and what the cost will be? I am referring to #3 in the diagram below... It is a Lefty Max FFD 140mm.
    Feb 2005
    Local Cannondale dealer is a great first call, was that not obvious though????
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    I found a bearing at a not so local bike shop. Got it all back together. Thanks....
    Reputation: alfa75's Avatar
    @jon.moab
    chack out my post with pictures . is this what happend to your lefty 2?
    http://forums.mtbr.com/showthread.ph...14#post7104514
    @alfa75
    The clip that holds the outer bearing races in has come loose. My problem was one of the actual bearing retainers (where 22 needle bearings are held in place) broke. I have the problem fixed and the fork is ready to go once again. Your issue is a lot more involved...
