    Reputation: RyukyuMtnBiker's Avatar
    Apr 2013
    Brake Pads for Helix equipped Cannondale
    I found a good ebay store that sells brake pads for my 2013 29er Trail SL 4. I know in the past many Cannondale owners were have difficulty finding replacement pads for Helix brake systems. I email the seller and he informed me that they do sell Helix 6 model brake pads for Cannondale bikes.
    X4PR TruckerCo s High Performance Disc Brake Pads Hayes Sole MX 4 MX4 GX C GX 2 | eBay
    Reputation: crazee horse's Avatar
    Sep 2012
    I use Hayes sole sintered pads. Direct fit. They are magnetic and easy to remove. Just don't touch your levers when they are out. You may need to push the pistons in with a flat edge. Let me know in your reservoir on the levers leak slightly .
    Apr 2013
    Quote Originally Posted by crazee horse View Post
    It your leaking brake fluid from your levers, I would suggest you take it to your LBS. If may be time to bleed your brakes or replace a seal.
    Sep 2012
    I lost a tiny drop through the breather hole in the middle of the reservoir. I'd have thought it was there for that reason ? Nothing happened after that. Brakes are fine.
  1. Brake Pads for Cannondales with Helix 6
    By RyukyuMtnBiker in forum 29er Bikes
    Last Post: 04-16-2013, 11:50 PM
  2. cannondale Helix 6 - upgrade or keep
    By Trail_Blazer in forum Brake Time
    Last Post: 10-06-2012, 03:39 PM
  3. Brake pads for Helix 3 calipers
    By DLew in forum Brake Time
    Last Post: 05-23-2012, 12:43 AM
  4. Cannondale Helix Disc Brakes?
    By Spykr in forum Cannondale
    Last Post: 12-01-2011, 12:01 PM
  5. Replies: 11
    Last Post: 01-11-2011, 06:15 PM
