Brake Mounts
Does anyone know if the Cannondale Super VSL uses IS brake mounts?
I believe that Cannondale have always used IS disc mounts
But it is easy to tell.
If the holes on the disc tabs face outwards 90 degrees side ways from the bike then they are IS.
If the holes face directly backwards on the fork or directly upwards on the frame then they are post mount style.
- You may not post replies
- You may not edit your posts
Forum Rules
