Results 1 to 41 of 41
    Aug 2010
    blown out headshok advice
    Just wanted to see if anyone had any experience with this scenario.
    I think i blew out the seals or blew out something on my 2008 headshok dlr on my 2008 cannondale f3. Im not sure exactly what the problem is yet.
    I was wondering if anyone busted a headshok and if they know if they are fairly cheap to fix or if its not worth it and to go another fork. My warranty is def over so thats not an option. My fav riding is quick singletrack so i was tossing up the idea of a white bros carbon fork if the headshox is not worth it to fix. Not sure if they would even fit the bike or not, the steer tube looks a little larger than most.
    Sorry for the ramble, pretty much just want to see if anyone has killed a headshok and what have they done (aka fix it/toss it and get another shok/throw on a carbon fork).
    Thanks in advance.
    Feb 2005
    Quote Originally Posted by csm929 View Post
    Thanks in advance.
    If it has been a reliable performer, chances are quite likely it can be again. Certainly for far less $ than a new carbon fork too.....
    Typically it's seals getting old, hard and flattened that cause them to crap out, much like any other high performance product. routine maintenance is required to retain proper performance. Cannondale recommends once a year service, @ 2008, I'd say you got more than your moneys worth out of that service interval.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    I've blown the headshok on my 2009 F4 a couple of times now. The first time it cost £30 to repair - the bottom out spring broke, second time the seals went bottom out spring bent, the headshok hydraulic piston broke and allowed the oil passed the seals - cost including fitting £130.
    The white plastic disc (plastic I ask you!) you see in the picture is sposed to be attatched.
    Here's what it looked like.
    Attached Thumbnails Attached Thumbnails blown out headshok advice-imag0212_336-1.jpg
    Aug 2010
    Yes absolutely right, ive bashed and beaten the thing for years before anything happened so i did get my moneys worth haha. Alot of people rip the headshok but i felt it was a really great fork (i ride a SS 26er f3 hardtail on some rough stuff) im not babying it. I think the fact that im only 175lbs might have helped the longevity of the shok too.
    I guess what I should do is take it apart and then show my bike mechanic to make a call so i dont have to pay labor to disassemble. Then maybe he can let me know (hes a trustworth guy so im lucky).
    I started thinking more about a carbon fork and on a 26er with some of the rough trails i ride - i will end up eating face. I guess if the headshok rebuild is not worth it then i will have to get another fork.
    Heres another questions - if i wanted to put a fox fork on, i would just have to get a new headset and it would fit?
    Reputation: SpiderMike's Avatar
    It would be worth it to rebuild. I've only busted the seals once on my 09 F3. The current internals has survived through me sheding weight, carrying my daughter around, and many stealth potholes/roots.
    Knowing it is almost time to replace has me at a different "fork" in the road. Rebuild the headshock, or switch over to Lefty?
    I really like the headshok despite wrecking it and having to have it rebuilt twice. I'd get the headshok rebuilt - well worth it IMO.
    Aug 2010
    Thanks everyone for your input it really does help - i think im going to go the route of rebuilding the shock. Ive had nothing but enjoyment with it and like the performance despite what the critics who idolize every fox fork out there (they are amazing too but i ride the same trails as the fox people just as fast and pleasurable with my headshok). Plus the top lockout is a life saver sometimes. Im going to see what need to be done and then go from there.
    Aug 2010
    Ok so im going to rebuild - should I contact cannondale to see if there is a specific place they take them and rebuild them? Has anyone send it out to have rebuilt? Or are cannondale going to say they dont want anything to do with it?
    Reputation: dyusem's Avatar
    MendonCycleSmith (who posted above) would be your best resource.
    I've got a '09 F3 that needed to have the bearing re-set at about 18 months and my LBA (Sunshine in Fairfax, CA) went to bat and Cannondale caved and covered it under warranty.
    I was kinda hoping that you would go the lefty route as that may be how I evolve my ride at some point down the line...
    Feb 2005
    Quote Originally Posted by dyusem View Post
    Just curious, am I misunderstanding you, or are you saying that you got a fork warranted for bearing migration?
    Makes no sense if so, it's normal, routine maintenance, and can be reset in about 5 to 10 minutes by any dealer with the proper tools....
    - FrostyStruthers
    Sim
    Sim is offline
    I sent my Lefty to MendonCycleSmith last year. He did a great job, got it back to me pretty fast and the price was very reasonable. The local dealer was going to send it to Cannondale and I read that turn around times are not that fast.
    Aug 2010
    Ok thanks - i dont think my problem is routine, i rode it from 2008 till now and pretty rough at times and its been fine till last weekend when it started making a clunking noise and it would no longer lockout rigid. I can lock it out and it still compresses.
    Quote Originally Posted by MendonCycleSmith View Post
    I believe that I only mentioned part of the story: I just looked at my notes and the oil cartridge was also leaking and required replacement. If I'm not mistaken, Cannondale was out of replacement oil cartridges at the time and I had to wait a few weeks while they were manufactured by their vendor.
    Sounds plausible or still confused?
    Feb 2005
    Sounds better, but I'm guessing that the damper must have been damaged or defective in some way, as they are normally serviceable, many times over.
    - FrostyStruthers
    Feb 2005
    Clunking upon returning to top? If so, topping out. Simply needs a bearing reset. No lockout either means the seals are tired, and are either leaking, or simply allowing oil to blow past, or, you broke a lockout circuit shim, not a big deal to get fixed either...
    2008 till now is a a good run. Cannondale recommends once a year service.
    - FrostyStruthers
    Aug 2010
    Ok I spoke with my mechanic and he used to deal with cannondales yearsss ago but not for along time. He was wondering if anyone knew if there is any special tools you need for the new headshoks. He thinks there were some back in the day, and he prob has them around the shop somewhere if he could remember which tool he needed (he thinks there is a specific one to take it out of the frame).
    Also, does anyone have a diagram of the internals of the shok or know where to get one?
    Dec 2011
    Maybe it's too late, but the white plastic disc is an air piston. I've broke one when screwed it in by using a little bit more force that is necessary. However I've cut there M5 thread (in piece that is in shaft) and screw piston (disc) in it's place.
    P.S.: I didn't know is it important not to close this hole hermetically, so I have use not a regular screw, but the "tubular" from Shimano shifter (cable adjusting screw), it also have M5 thread.
    Aug 2010
    Do you ever sell rebuild lefty forks? Or you just service them only. Just wondering. I would love a lefty for my 08 f3 but for the price of them new i might as well just get a new bike.
    Feb 2005
    I have, but it's not a normal part of my business and sadly, I have none currently. I've seen several (as well as recently scooped a few for Fat Leftys) for ~$300 on eBay and CL. Not too bad. Many will just need a service to be back in first rate shape. Not a bad call if you want more travel but don't want to break the bank.
    - FrostyStruthers
    Reputation: broomhandle's Avatar
    Fox also makes forks. 300 you can get a nice fork.
    Aug 2010
    I was thinking of going the fox route but i wasnt sure if its a better idea than the headshok fix. Im not going to do a lefty due to the fact that i need a lefty hub too and i would have to rebuild my front wheel which said and done if it doesnt come out right i would have to pay to get it right and its just too much at that point. Most likely i will just fix the headshok, ive had alot of good luck with it and its taken some hard hits many times and held up for a long time. I think that me weighing 180 might have kept the lifespan a bit longer too.
    Im going to wait a few months before spring comes to do anything, but if i was interested in getting a fox fork what headset would I need for this frame and how much do they approx run?
    Also, do fox forks last that much longer? Ive always wondered this. Alot of serious riders bash the headshok from what ive heard/read and everyone pretty much rides a fox (which i guess shows 2 things, they are worth it or fox corners the market because they are so big).
    just type in mountain bike in google, or downhill. and most people do ride fox. the headshox is a great fork, but its a 80mm fork. the fox shocks are adjustable from 100-140 on some. Fox makes dune buggy and motorcycle syspension. they know what they are doing. I think that might be why they have the market. they have been doing bicycle for awhile. I am a huge fan of the lefty, best handing fork ever. i have also blown 3 of them. but your right, they go for a lot even used, and you have to get a hub/rim....But a fox you will needa headset adapter.... i have bashed on my fox talas since 2007. it still feels the same since 2007.
    i love both, but cost wise. i would choose a used fox over a used headshox.
    Aug 2010
    Thank you broomhandle! (LOL great name), i really appreciate that feedback from someone who has experienced them all. Your completely right abot Fox knowing what they are doing. I dont have a huge budget (im a car guy too - my karmann ghia like me to spend money on it too) so im going to just assess the headshok, too much or not worth it and get some extra dough go with a fox.
    Where could I get a fox headset adapter for a headshok, is it a special order item?
    Feb 2005
    Sight unseen? Assuming it's repairable, worst Headshock reincarnation, around $150.
    $300 is going to be for a well used Fox, which'll likely need new seals and a rebuild for $50+. Adapter, headset and stem, another $75 to $100.
    All to get you a fork that doesn't use all it's travel, will tend to develop creaky clicky crown syndrome, and has more stiction than your kid brother with his butt superglued to the linoleum floor.
    Hmm, decisions decisions......
    - FrostyStruthers
    Aug 2010
    Haha well put! Ive decided to rebuild the headshok this time (ive had nothing but enjoyment for years and it took a hell of a beating) and then next time consider other options if it doesnt last too long after the rebuild. My friend has a fox and doesnt think its much better than my headshok for the riding we do. I guess if i was launching off 10ft rocks it would be a diff story....
    the used part is the hard part, its a 50/50. really any shock used prob needs a rebuild. re-building the headshox is cool because it keeps it original. and the color match's too!!!
    Aug 2010
    The color match is key too, i have the BBQ black (aka matte black) paint job. Im actually thinking of spraying a clear coat over it before it completely rubs off. Thats the only drawback about that paintjob. Right now i just have cable rub but eventually without the clear protection it will def start to come off.
    Aug 2010
    Also if anyone else with the headshok has the answer to this stem question I would appreciate the help.
    I want to swap out the stock stem on my 2008 f3 for a thomson one (i would like a stem with the same specs as the one on it now) - does anyone know off hand what that would be?
    Im not near my bike, wont be for a little while otherwise i would measure. Thanks in advance.
    Aug 2010
    So i read that the headshok stem on the 2008 f3 is a 1 9/16 steer clamp size. Does that mean the headshok has a headshok only stem? I couldnt find a thompson stem in this size. Im not sure it that means i cant get a different stem for my dlr fork.
    Has anyone changed the stem on their headshok?
    Aug 2010
    So the verdict is a blown O ring - anyone know where i can pick up the kit?
    Is their any company that makes a rigid fork with a 1.5 steerer tube to replace the Headshock ? I have a 2001 F500 I was thinking about replacing.
    discombobulated SuperModerator
    Jun 2005
    Quote Originally Posted by poconomtbiker View Post
    I imagine you'd use a regular steerer with a special headset....Mendon?
    Feb 2005
    Quote Originally Posted by CdaleTony View Post
    I'm sure Walt could build one, but yeah, 1 1/8" threadless, and one of these....
    Orbit DL 1.5R
    - FrostyStruthers
    Orbit DL 1.5R
    Thanks guys, I heard about the headset change. Mendon, Since you have seen many headshocks, is their a way to fabricate something that would convert the headshock to rigid fork? I new a guy years ago who used some pipe and he was able to convert his old RST to a rigid. It didn't look that good but it worked.
    Feb 2005
    Well, if you really don't care about ever using the fork again? Mix up a nice batch of salty water, droip the boot, and run the water up into it, severral times over a week or two.
    It'll lock up tighter than yo mama's chastity belt.
    Seriously though, that will work. Why the need, fork doesn't work anymore? Squish, more times than not, is better than none....
    - FrostyStruthers
    Thanks again Mendon. Shock is way to squishy and 10 years old on a bike I have set up as a commuter/urban assault bike. I dont want to spend any big money on it. I have 2 other Mt bikes that have front suspension, I would like to have 1 set up rigid.
    Can anyone recommend a place to buy the necessary parts to do a rebuild of a Headshok?
    Feb 2012
    I just recently got a used badboy 2001 ultra to ride to work. Unfortunately, after sending away to cannondale and waiting 6 months, I am now told the headshok is completely shot and needs a new cartridge. Since my bike is older, they no longer have the cartridge i need in stock. They offered to upgrade my headshok for 300 for a new one.
    Anyone think this is worth it or have an alternate idea on something that might work? I often see many lefty cartridges on ebay, would one of them work?
    Did you consider going with a rigid fork ? I was thinking about going rigid on my F500I just don,t want to replace headset and stem along with fork. I am trying to find a rigid fork with a 1.5 steerer.
    Feb 2012
    Ya, a rigid fork would work just fine for me. If you find a good deal on one let me know.
    makin skid marks
    regenerate zombie thread
    MendonCycles, you're cracking me up! I emailed your business re a Hedshok rebuild, but thought I'd check in here as well; I recently picked up a used first-gen Scalpel and will have either my LBS or you rebuild the fork, depending on a few factors. Mainly, parts availability- my local guys are a former Cannondale dealer so they have experience but cannot get parts.
    Turnaround & cost are smaller questions. Thanks.
    Actually I abhor cycling- I just like wearing tight shorts
  1. blown headshok. discontinued for parts.
    By harrisonv900 in forum Cannondale
    Last Post: 11-16-2015, 11:09 AM
  2. Need advice for a Headshok replacement
    By alex.y.kagan in forum Cannondale
    Last Post: 09-15-2010, 09:14 PM
  3. Blown headshok
    By hillbilly_hank in forum Cannondale
    Last Post: 08-30-2010, 06:42 AM
  4. blown fox dhx 3.0 -- not a rant -- looking for advice
    By virginhucker in forum Downhill - Freeride
    Last Post: 08-20-2009, 09:28 AM
  5. Advice please, upgrading OLD Headshok
    By Wildstar87 in forum Cannondale
    Last Post: 04-27-2005, 04:27 PM
