Results 1 to 6 of 6
Thread: Blown headshok
    I need a new name
    Blown headshok
    I have the chance to get a decent deal on a Cannondale hardtail with a blown Headshok. It locks out fine but when not locked out, it blows through the travel with any weight on it. Is this a common issue that can be repaired without too many specialty tools? Or would I be better off to just get a headset to adapt to 1 1/8" and put another fork on it?
    i ride bikes
    Depends on the model , a lot of time if it still lock , all it needs is some new o-rings and fresh oil and you are good to go again. Send it to Mendon and he will fix it good for you.
    Music & Bikes
    Reputation: fokof's Avatar
    If the lock works , means the oil cartridge is OK.
    The problem is the air cartridge.
    Have you just tried to add air in the fork ?
    (-+100lbs with a shock pump)
    "There is a big difference between kneeling down and bending over" -FZ
    Reputation: jimbalaya's Avatar
    like the other guy said, "send it to mendon."
    mendoncyclesmith.com
    "where pigs fly"
    I need a new name
    I learned something, Headshok's have an air valve. I guess the moral of the story is RTFM. Pumped it up to 90psi and it works fine now.
    i ride bikes
    Outstanding!!
