Results 1 to 6 of 6
    Blown damper seals
    Is blowning the damer seals in a lefty DLR2 a common problem? Is there something I could have done to cause this? and what can prevent this from happing again?
    Feb 2005
    Quote Originally Posted by Zoned
    Which seals, what are the symptoms? It's not too common, so therefore, it's all your fault
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    hello,i lost rebound and lockout in about 10 minutes
    Feb 2005
    You have a bigger issue. Possibly a cap that came unscrewed, or some such thing. Do you have a large quantity of oil leaking out from your boot? It's not a comon thing, I would get it checked out asap.
    - FrostyStruthers
    I didn't see any oil leaking out. It has pressure just no dampening. I'll have to get it checked out.
    Caution;  Merge;  Workers Ahead! don't ride it
    Those symptoms are exactly the same as what happened to my fork about 15 minutes before the whole thing fell apart!!! Do not ride it. I did thinking it was just a loss of dampening ... accompanied by loss of the lockout... See the recall notice on these forks!
