Results 1 to 3 of 3
    Reputation: qwackers's Avatar
    Aug 2005
    The best use for a Lefty top cap yet!.
    As iv been doing alot of epic rides lately using the GPS on my mobile (Satio) has come in realy handy so i wanted to attatch it to my bars for better use....
    Looking on the internet all the ones i found were universal types with bag clamp and over sized clamping jaws etc....
    So a little thought later i came up with this....
    Drilled a hole in the top cap and put some black tape around a small steel ruler i had which already had a hanging hole in it....then bolted it with washers and a nylock nut inside the top cap....once fitted back onto the headtube It rests nice on the top of the stem and could even be cable tied around for extra security....
    Put a bend in the ruller to get my angle the super glued my mobile sillicon case to the stell ruller to create a perfect tight fit so i can easly pop the mobile in and out....or just remove the lot by taking out the plug....
    P.S. ....its not an easten stem ....just a sticker so it matches the bars and post....
    2002 M Cannondale Jekyll Goodboy 30th Aniversery...#017-300....
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Nice!
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    nice work,
    Just dont look at the thing too much, you will be down eating dirt
    Lead by my Lefty............... right down the trail, no brakes.
