Results 1 to 14 of 14
    Best after market BB for F-SI maybe ceramic
    anyone change theirs. Any style will work best ?
    Quote Originally Posted by promtber View Post
    I'd like to know this too as my 1 year old Scalpel BB is creaking like a mofo! Chris King PF30?
    I did not change the BB but I did change the bb30 bearings to SKF, they last longer. I have no creaking solar.
    Chris King PF30 is top of the bill of course !
    Ron
    I changed the bearings to SKF bearings as well, works great!
    BBinfinite ... Ceramic speed , both worth the money
    XD-15 Enduro.
    "In addition to chromium steel, we use XD-15 material for our special top end ceramic bearings. This is a very special nitrogen infused steel material and will not rust or corrode. It is more than 5 times the corrosion resistance of 440C stainless material. The process to make this steel involves remelting a very high grade of martensitic stainless steel from the end of an electrode. This occurs in a highly-controlled remelt chamber while introducing nitrogen gas, producing a homogenous steel free from course carbides and giving ultimate fatigue resistance. A super strong steel made for ceramic balls, XD-15 is the pinnacle in bicycle bearing technology."
    Reputation: turnerth's Avatar
    Aug 2010
    Smile
    not Chris King pf30, I have it in my evo. They use thick plastic spacers that cause the bearings to be tiny, same bearings they use in some of their headsets. My bb spins less freely than other pf30s I have installed, fsa and wheels manufacturing.. very disappointing. Install was smooth.. I really think the CK design is the problem. Not that it slows me
    down, I just prefer a more free spinning bb.
    My next pf30 will likely be wheels manufacturing / enduro.
    Massage Blocks :: The Ultimate Trigger Point System
    Can you confirm BBinfinite with F-SI?
    Quote Originally Posted by xavier lord View Post
    Will the PF30 BBinfinite work on the F-SI (2016 particularly)? How can I confirm? Is it just a normal PF30 bottom bracket, with spacers and chainrings for the chainline?
    BBinfinite will not work as they do not offer a 83mm width BB.
    The FSI's bottom bracket size is 83mm, and BBinfinite only offers 68mm or 73mm for MTB.
    Ron
    Nov 2017
    yup. 83mm.
    Dec 2005
    Quote Originally Posted by nelsontod View Post
    yup. 83mm.
    hope bb. good construction + 83mm model available
    Jun 2016
    Installed Ceramic Speed bearings. Aluminium inserts. No creaking.
    Reputation: Chrizzzz's Avatar
    Feb 2016
    I nearly destroyed all bearings without inner shell because most of the water and dirt came from the inside.
    So i went from Ceramicspeed to WheelsMFG and they really work great so far!
    Better sealed cups/shell/dust covers. Everything seems to be more progressive and thoughtful.
    For sale:
    - Cannondale 2x Spider XX 120/80
  1. Ceramic Coating
    By Clockwork Bikes in forum Frame Building
    Last Post: 06-01-2012, 05:51 PM
  2. Not sure which CK Ceramic BB to get for E.13
    By AaronJobe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2012, 05:16 PM
  3. Ceramic vs steel BB
    By ratherbeintobago in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2012, 07:09 AM
  4. ceramic BB vs. XTR
    By epic in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-10-2011, 12:23 PM
  5. Ceramic bearing Q
    By crazyjeys in forum Wheels and Tires
    Last Post: 04-01-2011, 02:07 AM
Members who have read this thread: 33
