BB30-to-Standard English Thread Adapter
I want to bid on this auction: http://cgi.benl.ebay.be/ws/eBayISAPI...=STRK:MEWAX:IT
It says: 'hard to find standard threaded bottom bracket shell'!
I thought all carbon frames have a BB30 bracket accept the ones with a 'BB30-to-Standard English Thread Adapter', so I can remove the adapter to install a BB30 crank.
Thx for the advice!
no man !
this BBQ frame is with standard english cups ... no BB30 !!
cannot be removed anything there !
Thx Eliflap, you helped me saving a lot of bucks!!!
Yep... What Eliflap said.
In FTF We Trust
Plus, once you put a standard threaded BB adaptor into a BB-30 frame there's no going back (thanks to green loctite).
"I'll disintegrate over time if I expect my body to try to keep up with my mind" -BM
Race, Rocks or Road...Just Ride
Is there anybody who can help me finding a Scalpel carbon BBQ with BB30?
I prefer a new or slightly used frame, with or without Lefty or rear shock.
oh , adaptors are removable . with maximum care ..but removable . all .
but not that frame ...it's born English ...must live in that way ...
cannot have BB30 passport
In FTF We Trust
Hmmm...as per Cannondale's Carbon Rush manual I have: "CARBON RUSH STANDARD BOTTOM BRACKET SHELL THREADED INSERT (1) IS PERMANENT AND NON-REMOVABLE. DO NOT ATTEMPT TO REMOVE IT. YOU CAN CAUSE SERIOUS FRAME DAMAGE.
Once installed, the adapter is a non-removable/ permanent frame part.". I'd love it if that was wrong, but I don't know how the heck you remove a metal part installed with green loctite. If there's some trick I'd love to hear it. My Carbon Rush had the insert installed in it when I bought it.
removing the adaptor will make a big 'CRACK' noise, that may make you poo a bit, but it will press out. if the press is applied correctly to the aluminium surfaces of bb shell and adaptor, it should not effect the carbon bonding as the carbon surrounding the bb shell won't be affected by the pressures applied.
but if cannondale say it should not be attempted, don't DO IT.
sorry never had a Rush ... only tried one ride
there is lot of confusion...
one thing is a frame with english permanent adapter as BBQ scalpel on auction ...
other thing is the removable adapter ...
a friend removed it from a 2007 Cannondale Taurine himself , with no professional tool ...
no problem doing it ... no problem at the bike since many months are gone
other friend done in a 2008 alu scalpel TR ... again no problem
The adaptor is removable but not under just any 'mechanic'... It's easy to mess it up and some might not use the right tools and techniques (using a torch to melt the loctite then hit it out with a hammer is not the right technique), so Cannondale are going for safety and say it's not removable. Basically, you can do it but at your own risks, if you mess it up or if the area ever cracks, BB sleeve unbonds from the carbon shell or something, don't expect a warranty.
Hi,
I pressed out the threaded bb adapter from a 2009 taurine frame.
There was no evidence of any loctite having been used between the adapter and the bb30 aluminium sleeve.
If you are doing it, check the tech note on cannondales website and make sure you only ever press against the alumium sleeve and not the carbon frame itself. And, of course, be very careful, as DG says its all at your own risk etc !
Cheers !
Just so you know, there's a thread in the Drivetrain forum that's about doing the opposite of what this thread discusses: installing Cannondale BB30 cranks on a frame that has an English-threaded bottom bracket. Here it is: BB30 crank on non-BB30 bike.
- You may not post replies
- You may not edit your posts
Forum Rules
