Results 1 to 7 of 7
    Reputation: baalan's Avatar
    Nov 2007
    BB30 bottom bracket adapters
    Does anyone know if the THM/Zipp BB30 bottom brackets are made to thread directly into a standard english 68mm frame or if anyone else is making kits for standard frames?
    '96 Uber Light
    '00 R3000 TT
    '08 Six13
    gmk
    gmk is offline
    angels get bald too
    Reputation: gmk's Avatar
    Quote Originally Posted by baalan
    you need a BB30 SHELL ADAPTOR
    http://www.fullspeedahead.com/fly.as...layout=product
    sorry
    im wrong
    i missunderstood the question
    "Show your bike some love and it will show the love back."
    Eric, niner bikes
    the most important vehicle is a 29er bicycle
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    Quote Originally Posted by gmk
    completerly wrong !!!
    why a shell of 42mm diameter can fit a 36mm or similar english thread shell ?
    reset:
    http://www.thmcarbones.de/en/clavicula/zubehoer.htm
    the THM BB30 adapter ( named in the page , BB30 Bearing cup ) is for a BB30 frame and it permits you to tight a THM external cups into that frame
    in a english thread frame you need only the THM cups ( named in the page Bearing shells with bearings )
    but you need a no lip BB30 spindle to install a SL or SI Cannondale crank or remove the black left arm preload nut in a SI Carbon Cannondale crankset.
    May 2010
    As said above, your thinking in the wrong direction. It's usually BB30 frame to English Crank set. Now I realize the Cdale Hollowgram SL crank set is nice, but I dont think you would get much of it's benefit trying to retrofit it to an English BB frame
    Lead by my Lefty............... right down the trail, no brakes.
    Nov 2007
    So the thm cups will work? I'm just kicking ideas around to get a Cannondale crankset on my F3 and my 6 13. If it has no real benifit it would be money wasted other than pride of ownership.
    '96 Uber Light
    '00 R3000 TT
    '08 Six13
    In general, any kind of adapter to make something work will have some compromise. There are good std English cranksets that will cost you less than the Hollowgrams. Shimano XT and XTR come to mind. Also, SRAM XX and X.0 (2011) are showing some promise. You also have a lot more option for road bikes.
