Results 1 to 3 of 3
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    BB30 Bearings Ghetto Install
    Looks like I overtightened the locking nut on my Afterburner crankset and ruined one of the BB30 bearings.
    I don't have the press fit tool to install a new set. Would it be wise to just use a large nut, bolt and washers to do the install?
    I tried to do the same a few years ago. I suspect it is do-able, but the bearings went in crooked very easily and I was installing 1 at a time. I ended up taking it to the shop, it is very easy and fast with the proper tools.
    Thanks to www.weavercycleworks.com for my awesome bike frames!
    Jan 2009
    Arright, hopefully someone has an answer for this.
    Like I said in the OP, I crushed the bearing and now it won't turn. The problem is, I can only finger-tighten the Lock nut until it makes the crank not spin freely. The FSA manual specifies a torque setting, so I know it should be tightened more.
    The first time I removed the crank, the only washers or spacers there were the lock nut on one side and one spacer on the other side.
    I think Vergard had this problem???
  1. Should I replace my RF X-type bearings before I even install the BB?
    By head in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-13-2013, 06:29 PM
  2. Replies: 12
    Last Post: 12-22-2012, 08:16 PM
  3. Replies: 3
    Last Post: 09-13-2012, 12:37 AM
  4. Lightest external cup BB30 cups and bearings
    By Ottoturbo in forum Weight Weenies
    Last Post: 02-20-2012, 06:13 AM
  5. Force needed to install BB30 cranks?
    By apacherider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-04-2011, 07:10 PM
