    Just ride
    Reputation: skim1040's Avatar
    Bad Boy Jekyll - mountain worthy?
    I've found a bad boy jekyll locally that is cheap. I know there good bikes, but this one is the Bad Boy. Has the skinnies instead of the mountain wheels and tires.
    With the stock headshock that it has is it possible to squeeze a wider set of wheels with some mountain tires on there? Or is it stuck with the slicks on it?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    It only needs mountain wheels, the frame, fork are the same as a standard mountain Jekyll.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Just ride
    beutiful.
    BadBoy rear shock
    Yes , frame are the same , but depends on the year , watch out for the rear shock , some early model have one of the fat short air road shock from C'dale , those ones may not dig it if you are using the frame the way a Jekyll are meant to be used as a MTB.
