Results 1 to 10 of 10
    bikeboatbrewski
    Reputation: scottybinwv's Avatar
    Jun 2010
    assembling a Cdale Moto
    OK, got a stupid cheap deal on a Moto4 and now I need to put it together. The only thing I have a question on is the fork and how/where the several parts should go together?
    I am looking through the manuals and not really finding it. It appears the bearings them selves are in the head tube. I get the stem cap and spacers but there are a couple of rubber washers and a metal ring that I am not quite sure where these go?
    Reputation: amillmtb's Avatar
    Jun 2005
    Post pictures of these rubber washers and the metal ring, someone should be able to help. Which Moto 4 model is it US or International?
    bikeboatbrewski
    Jun 2010
    Its the Moto4 which is the alloy frame. I will get some pictures up soon.
    bikeboatbrewski
    Jun 2010
    Looks to me like one each of the two rubber washers go top and bottom of the head set bearings.
    The metal ring has a slot cut into it and a beveled surface one side and the other is flat, seems to fit right on the steer tube of the fork. Does it go top or bottom?
    Tried to get some pictures up but the PC is acting like slow. Maybe later.
    Why not take it to a LBS to have it assembled. I ordered an unassembled rize 2 and got it put together for $50. Unless you're doing it for experience then nevermind
    gmk
    gmk is offline
    angels get bald too
    Reputation: gmk's Avatar
    technical manuals on cannondale homepage
    ita all there ...
    "Show your bike some love and it will show the love back."
    Eric, niner bikes
    the most important vehicle is a 29er bicycle
    bikeboatbrewski
    Jun 2010
    I did go to the LBS and talked to a friend, he said I could do it no problem and the bike mechanic was not going to be back till end of the month. I did find the suppliment owners manual for the moto, it has a view of the HS and parts but does not everything.
    I will check on line for any more tech information, thanks for that tip!
    bikeboatbrewski
    Jun 2010
    The online tech manual information was basically the same as what came with the bike, it did have a better picture of the head set however. I should have it covered. Thanks all.
    gmk
    gmk is offline
    angels get bald too
    Quote Originally Posted by scottybinwv
    sorry
    but are u able to RTFM !
    i also did so at the rize
    the headset should be in the headtube (semiintegrated!)
    http://www.cannondale.com/deu/deu/Ca...plement_en.pdf
    page14, 15, 16 ...
    Eric, niner bikes
    bikeboatbrewski
    Jun 2010
    DONE!
