Results 1 to 9 of 9
    Feb 2007
    Anyone recommend a bearing grease?
    I cant find Royal Purple Ultraperformance grease in the UK. Can anyone recommend an alternative to lube the bearings on my Lefty Max (under the concertina boot)? Thanks for any suggestions.
    P.S. I know I'm probably being a bit anal but this this will be my first time!!!
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Any quality grease should do, I use Phil Wood grease mostly because I have lots of it... Your LBS should have something, just ask them for quality bearing grease.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Feb 2007
    Thanks for your time. Love your Blog. Regards
    Reputation: rumshcawheely's Avatar
    Quote Originally Posted by Baker921
    NEW RULE!!!!
    From here on out, no one shall use the words anal, my first time and grease in the same post!
    Feb 2005
    Quote Originally Posted by rumshcawheely
    Nice catch
    I use Du Monde Tech, but don't know about availability in the UK. As Dan said, Phil's great, but any waterproof grease should do the trick.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Feb 2007
    Thanks Mendon I shall look out for waterproof bearing grease. Finnish Line seems to be the quality option locally.
    Oh and Rumshcawheely its all about being comfortable in your own sexuality. If you feel the need to share I'm sure we're all here for you!
    Straight or Gay the joke works just fine. Rule Stays though!! By the way, that DuMonde stuff is really good. They make a few really good products.
    Feb 2005
    Yep, love the stuff. Their original formula lube is the bomb. I sell it, not many shops seem to, but it's worth digging for, I promise
    - FrostyStruthers
    Reputation: surf418's Avatar
    I used Finish Line's Teflon Grease.
    But i think i used too much of it in my rear hub Now the freehub doesnt "clik" anymore. I think it got from the hub to the freehub. I didnt tought it could go there. How much grease should we put into each side of the hub? Just enough to stick the balls in there or less or more ?
    Now i'll have to disassemble everything and wash it and do it again.
    What kind of oil should we put in the freehub?
    Regards.
    surf418
