Results 1 to 3 of 3
    anyone with F5 headset knowledge?
    heres the problem...... when you type 'F5' in the search the forum button I get 0 responses....
    I have half a headset on my 2007 F5.... the top is there minus the bearings.... the bottom is mostly missing.... so i want to get a new headset for a 1 1/8 fork...
    ive read tons of post about the big fat pig headset that some say work and others say it wont...
    can i get a final response to that question? will it work? is there another that does? the orbit?
    what i usually do is look through the 'post your F5' thread of other peoples bike builds and just see in a photo what works and what doesnt.... but for some reason that post is gone....
    thanks for the help in advance.....
    ok,
    i took a hammer and figured some stuff out.....
    i have an 07 f5.... will this fit?
    http://www.universalcycles.com/shopp...s.php?id=24455
    i figure every one would be using them if it were true....
    what does=
    This if for Cannondale Headshok frames. It will not fit standard 1.5 frames
    I am pretty sure my frame will take a lefty or headshock.... does that make it a headshok frame? or does this headset fit inside something else likje that SI headset that you need witht eh head shock...?
    Yes, that woodman would work on your Furio-X from (2007 F5)
    Quote Originally Posted by nicolicious
    i took a hammer and figured some stuff out..... FSA also has one
    what does=
