FAT BIKES
WINTER APPAREL
TRAINERS
Page 3 of 55 FirstFirst 1 2 3 4 5 6 7 13 53 ... LastLast
Results 51 to 75 of 1355
  1. #51
    koe
    koe is offline
    Apr 2005
    Looking great fatboyslimfast.
    I ripped my headshok apart and it is pretty much shite. I am goint to see about having it serviced when I get back to the states.
    I just picked up a Marzocchi MX Coil 85 to replace it. So we will see how that works out in a week or so.
  2. #52
    Reputation: Wick's Avatar
    Apr 2005
    Great job on the rebuild Fat's - that is one great looking bike. Did you refinish the paint or is that original? It looks awesome. Enjoy!
  3. #53
    The frame and rear triangle were sprayed by a couple of guys at the bodyshop where I work. You can't see it in the picture but the silver is the same paint used on car alloy wheels - in the sun it glitters and shimmys like a good 'un. The rear triangle is Volkswagon metallic black - there was an '04 Golf GTi in the shop and I asked for the same colour. It almost looks like a team replica. The decals were off a guy on e-bay, I'm keeping my eye out for some genuine Cannondale decales to finish the job.
  4. #54
    Retro scan/post troll
    Better 1994 1/2 pic's..
    Quote Originally Posted by 2ManyPlaces
    ......1994 1/2 (mid-year) model --- just like mine (notice where the red fades to silver down near the bottom bracket).. However, unlike mine, yours looks to be pretty much 100% original.. See my prior posts for how mine is currently equipped.. The black cranks shown are off of my 1999 C'Dale SV500 ).. Yours even has the 'Zochi rear shock..Mine came equipped with that rear shock, too.. .. I have the C-dale catalog and it shows a Fox rear shock in the picture and on the data info.. However, the switch to 'Zochi was made afterwards- a better shock at the time (in my humble opinion)If you want , I'll scan you the stuff for your files.. e-mail me if ya want it..
    i have current pic's of my 94 1/2, but I can't get the photo-attch thingie to open--- so screw it...
    Let's see if I finally learned how to load pic's.. 2 pic's should appear.. If this attempt works, I'll re-try posting my 1999 C'Dale SV 500 pic's again...
  5. #55
    Devolution is real!
    Reputation: toyota200x's Avatar
    WOW it is great to find this post. I have a 1999 super v 500. It was my first mountain bike and I recently bought a 1999 GT lts 2000ds and now I don't know which I like better. My headshok and rear shock need to be serviced on the V.
  6. #56
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    The latest incarnation of my 1999 SV900. I have added 8" Avid mechanical discs, Ritchey V3 Comp pedals, a new Mavic 317 front rim that I laced to a BBB hub myself and an Intense 2.35 front tire.
  7. #57
    Apr 2005
    Here's my '99 SV 1000, recently brought back to life with an older style yet otherwise new Hollowtech OctaLink XT crank setup (it's getting harder to find replacement square taper brackets these days), SRAM Rocket triggers (I think I'm formally done with twist shifters now) and the Magura HeadShok cartridge upgrade (I paid for 80MM of travel, now I finally have it). Oh, and pardon me if placement of the bike was a gratuitous attempt to also include the Mille. Wait, maybe even mentioning the Mille was gratuitous.
  8. #58
    Armature speller
    Sep 2004
    Nice bike Koe, just a bit tidier and more original than mine
    Although mine does have the original fox shock
    Wanna swap
    I've just broken my frame however.
    The thin strut from the seat downtube to the left side of the swingarm pivot has broken just above where it's welded to the swingarm bracket.
    Just need to get around to getting it fixed.
  9. #59
    koe
    koe is offline
    Apr 2005
    No dice, Bro
    Finally got it to about 100% the last thing is to upgrade the rear caliper brake.
    The latest upgrade was a Marzzochi MX Comp Coil 85. I was worried about the geometry so went with the 85. With the new suspension this bike is like a pogo stick compared to how it was riding a month ago. I have everything pretty stiff becasue I am riding mostly XC and Urban Freeride but I can get an extra 8 inches vert from a standstill.
    I recently decided to beat the hell out of it and took a 6 foot drop with no transition and it faired pretty well with the exception I did something to the bottom bracket so I pulled it all out and put it back together and all is fine.
    Some more SuperV porn for you all..
  10. #60
    Aug 2005
    all my SuperV's
    This are my Baby's from 1995-2001
    No Picture, a 1999 Charger Orange and a old maybe1994 violet with carbon swingarm
    aeiou
  11. #61
    Devolution is real!
    anyone else?
  12. #62
    Uber V Cripp
    Reputation: jdcamb's Avatar
    Quote Originally Posted by BikeSDP
    The 99 SV was a unique animal. The shock mounting tabs were moved forward 3/4" to accomodate the SL swingarm with a 6" I2I shock (Fox Vanilla usually). You can tell them from other incarnations by the size of the tabs and how far the tabs are from the seatpost braces. If you can find a Jekyll swingarm, some Super V adapters (which to mount a standard fork because the crown height of a lefty is not high enough), and a 7.5" I2I stable platform shock. You can potentially have a 6" rear travel trail bike.
    With these few upgardes (roughly $400/500) you can have a bike with roughly the same geometry as a Prophet set in the FR settings. The swingarm is stiffer then the Prophet as it is behind the BB (less span), it will have a very consistent rate of suspension (as compared to the Prophet which has a falling rate at the end of the shock stroke because the shock mount is on the down tube and more inline), and the arc of the swigarm is tighter then the Prophet making it more efficient. It will for the most part except modern parts, will weigh in theory less then 30lbs, and in my opine be a potentially awesome trail bike.
    jdcamb
  13. #63
    JDCamb is on to something I tried last year withouy much luck. I think I must have an older frame because when I tried to fit a secondhand Jekyll swingarm the i2i was about 200mm, for too big. Instead I had to plumb for a stock arm. It is something I'm still keen to try though.
  14. #64
    Demon Cleaner
    Reputation: Structure's Avatar
    Mine is a '97 Super V900
    It is also for sale. If anyone wants their own Super V or maybe just a backup!
    http://cgi.ebay.com/Cannondale-Super...QQcmdZViewItem
    Sorry for the spam. But it seemed like a good place for it.
    Bicycling is politics by other means.
  15. #65
    Uber V Cripp
    Quote Originally Posted by fatboyslimfast
    Dude I know I am on to something . If I could only find one those 99 short tab frames......
    Here is another shot of our third experimment. It rides awesome and it is a feather considering the parts spec. Solid feel super efficient climber. Nobody can believe the frame was made in 1997. The performance of the PS fifth element is just amazing. We had to turned up the valving to 3 : 1 to get the rebound into range on a couple of the frames. Anyone who rides it wants one. PM me for info....
    jdcamb
  16. #66
    Super V still a favourite
    Heres my Super V 1000SL. I bought it new in the UK. Some minor changes to it - Race Face post, Monkey risers, flat pedals (alternating between a set of XT SPD's). Love this bike for general XC stuff. I was going to sell it when I got the Prophet but have come to realise that there is probably room for both bikes (parting with the V started to get tough when it came down to it!).
  17. #67
    Apr 2005
    Love those Super V's
    Very nice Tony- I am glad you have kept the Super V - that is one great bike and a classic! Enjoy!!
  18. #68
    Super V 2000
    Quote Originally Posted by toyota200x
    anyone else?
    Yep
    Here's mine, think it's a 94-95. The dropouts have detached themselves from the swingarm a couple of times... what would I do without JB weld
    This was taken a year or so ago and have changed a few bits since. I mainly use it on the road now and as a back-up and a loaner.
  19. #69
    Devolution is real!
    Quote Originally Posted by jdcamb
    jdcamb
    Hearing all this great hop ups make me want to keep my super v. I currently have a GT lts 2000ds as my main FS bike but I still love the super v. I am not totally understanding what is different about the 99 frames. Is it the supports that are bumped out that go from the seat v to the frame? Please explain.....thank you.
    Also can we see the other experiments? Please..........
    I understand now.......ooooops........that is a big difference in the shock tab length.
  20. #70
    Quote Originally Posted by dirkdee
    Yep
    Now thats what I call a Super V!!!!
    Just as important - whats cooking on the stove top?
  21. #71
    Reputation: rw420's Avatar
    Dec 2005
    Rasta V
    I've put together several combinations with Super V frames but this is definitely my favorite:
    1999 Super V Front (short tab)
    2004 Jekyll Swingarm
    7.5" x 2" Progressive 5th Element Air
    Fox Talas RLC Fork
    Gets over 6 inches rear wheel travel and still climbs anything without a hint of pedal feedback thanks to the 5th Element. The fork is installed with Cannondale Super V headtube adapters and a Chris King headset. It has perfect trailbike geometry.
    I've owned an Ellsworth ID and several other Cannondales but this is easily the best trailbike I've ever ridden. Might not be pretty, but it rocks.
  22. #72
    R.I.P. DogFriend
    Long live the Super V!
    Just curious what the travel of the fork is?
    I must admit the thought of 6" of rear travel has my attention.
    The original configuration of the 99 Super V was out of balance IMHO with 120mm rear travel and 80mm in the front.
    To those that have ridden this setup, what do you think the ideal fork travel would be?
    Regards,
    Jeff
  23. #73
    Dec 2005
    Quote Originally Posted by jeffj
    Regards,
    Jeff
    You won't realize how nice more travel is until you try it. I never thought I needed 6 inches
    but I keep managing to use it all...
    I have not ridden an original Super V. I began experimenting with Super V frames
    because I had a 2001 Jekyll and wanted a modern platform shock. First I tried the Raven II
    with a Romic. When I broke the Raven C'dale gave me a Super V. I got a 5th Element Air
    and never rode the Romic again. That combination gave me 4.5" with a modern Jekyll
    swingarm. Eventually I tried the newer 135mm Jekyll with a Swinger shock but it just
    doesn't compare to the 5th element so I sold it. I just recently discovered the short-tab '99
    frames that allow the use of a longer shock with a modern swingarm. I believe I have
    found my perfect trailbike. Any '97 or newer Super V frame could be modified to shorten
    the tabs. I haven't tried it yet but it seems like it would be pretty easy with a drill and
    some dremel work. I'd like to know if anyone has tried it.
    The fork is a 125mm Talas. It's a pretty good match to the 5th air, especially given the
    upright riding postion and rearward bias of the bike. I also plan to try my Z1 FR SL for a
    bit slacker geometry. The Z1 is an inch taller. By using the Super V headtube adapters,
    you have some flexibility in geometry - steeper with the 1" cone on top, slacker with it on
    the bottom.
  24. #74
    Devolution is real!
    Quote Originally Posted by rw420
    Fox Talas RLC Fork
    Wow you have done some amazing work with superv's.....WHere are you finding these new Jekyll swingarms and how much money are these 5th element shocks?? Keep up the good work and lets see some more of your bikes.
  25. #75
    Dec 2005
    secret formula
    The swingarms are still available through your Cannondale dealer. I've also found them here and on eBay. You can use any Jekyll/Raven/SuperV swingarm made since 2000 with the same results. Look for the ones with the furthest offset rear shock mount. I prefer the newer Jekyll models for strength and tire clearance even though they're a bit heavier. I've broken a couple CAAD4 versions over the years.
    5th element shocks also show up here and on eBay. Of course you can always order the 5ths and mounting hardware through your LBS.
    As for previous projects, here's a pic of the first 5th element Super V I put together. It gets a FULL 4.5" of travel (feels like more). I loaned this one to jdcamb for a while last year. It wasn't long before we were building his Daisy. If you want to see Daisy, look up his post in this thread from about a month ago. We have also put together a Raven II with a 6.5x1.5 5th air and a CAAD4 swingarm with good results.
  1. 888rt vs '03 Super T
    By I_8_It_up in forum Downhill - Freeride
    Last Post: 08-03-2004, 07:40 PM
  2. Black Super SPV 80 or Skareb Super 100?
    By Dirt Pilot in forum Shocks and Suspension
    Last Post: 05-06-2004, 04:22 PM
  3. Pictures: sunset jumping, berms, super ghetto drop
    By ThoughtfulPirate in forum Downhill - Freeride
    Last Post: 04-04-2004, 04:37 PM
  4. Farewell my Super Sized friends....
    By PROGRE-SS in forum Passion
    Last Post: 03-04-2004, 04:21 PM
  5. 04 super t vs. 03 super t
    By 2slow in forum Downhill - Freeride
    Last Post: 01-29-2004, 03:20 AM
Follow MTBR on Facebook
