Results 1 to 11 of 11
    Reputation: nathanbal's Avatar
    Another Scalpel chain ring question...
    What are the options for the 29T chain ring on a hollowgram 2x9? I have been searching for 5-bolt, 29T, 94BCD rings and I cant find any online. Has anyone replaced the stock one? Mine is starting to get worn out and chain-sucking so will need a replacement shortly.
    GTaholic
    I do make a 29T for Hollowgram 2x9.
    Mail me at mattias@hellore.se
    Experimental Prototype
    Thanks, went to the links and middleburn, blackspire, vuelta and salsa dont do 94bcd, 5 bolt 29t chainrings. Am I missing something?
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    i have a TA Specialites , silver 29T 94mm BCD
    if you want an original replacement any 'good' cannondale should be able to get you one.
    Quote Originally Posted by parkincake
    i realise that, however I was looking at alternatives.
    Reputation: HAL 9000's Avatar
    what is wrong with the stock cannondale 29t chainring?
    like they said any decent cannondale shop should be able to get you a 29t ring or you can always try ebay.
    the first link i gave you dr.cannondale is your answer or eliflap with the TA Specialites ring if you can live with silver.
    thanks. nothing wrong with the stock chain ring and i will be going down that path.
    is there a reason why there are no aftermarket alternatives?
    LA CHVRE
    Reputation: Dan Gerous's Avatar
    Because most people stick with 22/32/44 and also because most crankset nowadays use the 4-bolt 104 BCD, not the 5-bolt 94 BCD. The market for 29T 5-bolt rings is pretty small and might become even smaller, even Cannondale is switching to the new 80/120 BCD of SRAM XX for 2010.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    FRM used to make one, but availability in the US might be scarce. I bought one from Notubes.com a few years back, but they no longer carry FRM parts.
    Thanks to www.weavercycleworks.com for my awesome bike frames!
