Results 1 to 19 of 19
    Alternative Lefty Stems
    I am sure this has been posted, but I could not find it....
    I am interested in some lightweight stem options for a Lefty.
    Anybody?
    frm is the lightest
    Reputation: HAL 9000's Avatar
    looking for a 110mm 5- degree Cannondale XC3 stem/steerer can only find a 100mm or 120mm do they even make a 110mm XC3?
    Reputation: PG256's Avatar
    Quote Originally Posted by HAL 9000
    Nope, they don't make the Si XC3 in 110.
    hope makes a shorter stem
    The hope ones are cool looking and come in 90 and 110 mm. I like the red one!
    Although, from what Dan G said, they a tad heavier than the std (non XC3) stem.
    Lead by my Lefty............... right down the trail, no brakes.
    Cannondale does make the 110mm Stem/Steerer in 3 different rises.
    -5 degree- part number QSD110-5318/BBQ
    +5 degree- part number QSD11005318/BBQ
    +20 degree- part number QSD11020318/BBQ
    Dec 2009
    Hello everyone!
    I need to know if I can put a Cannondale XC3 SI stem with 90mm / -5 in a Flash Hi-mod using a lefty suspension and a flat handlebar? I ask this because I was told that probably would have to be a +5 stem because with the -5 the handlebar would hit the lefty!?
    Thank`s for your help and if someone is using this setup please post some pictures?
    HR
    If you have one of the new Leftys with the OPI Alloy upper, a -5 x 90mm will work. The carbon uppers are larger in diameter and get really tight.
    Dec 2009
    It`s for a Lefty Speed Carbon SL 110mm Solo Air OPI...
    Quote Originally Posted by PG256
    They actually do.. my 09' Rize (sz Large) came in 110mm +5. Yes I was a bit surprised when I saw the marking on it. I thought they make 90mm, 100mm, and 120mm only.
    Feb 2012
    Just jumping in here, but anyone know from where I could obtain (pref. in the UK) a spacer to fit under the stem to raise it up the steerer tube?
    Does a std. 1.5" spacer fit over the Cannondale HeadShok steerer? Or does one need to get special Cannondale versions? In which case, where from?
    Livin' the Dream
    Reputation: Asbury's Avatar
    This may work:
    http://www.transitionbikes.com/Store_Detail.cfm?Token={ts_2011-12-29_22:00:38}-f86bc916d196a338-E16F2859-08C1-76C0-3B5139A08E8C6E18&P=1417&o=2
    DO RIGHT AND FEAR NO MAN
    Feb 2012
    So, are you saying that a std. 1.5" spacer will fit over the Cannondale HeadShok fork tube?
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    the world can be black , white ...or grey ...
    this time is black
    -17 degrees Zipp Beyond Black Service Course 100mm stem on EP tube
    Attached Thumbnails Attached Thumbnails Alternative Lefty Stems-img_2904.jpg
    Oct 2007
    Eliflap, That camelback water bottle looks a bit heavy for one of your bikes! There has to be a lighter bottle out there?
    FIRENZE rulez !!
    Quote Originally Posted by norty_mtb View Post
    sure ... but sometimes heart leads ...
    Stems for Lefty
    here..Rotor Stems and the NEW Cannondale 100mm -5 original 173,2g, the other with Titan Bolts an Syntace Clamps 144,9g--
    Quote Originally Posted by wv_rider View Post
    Along the same lines, does anyone know if the OPI -15 x 90mm will fit? I have the OPI -5 x 90mm right now and it already a pretty tight fit but I am looking for a lower handlebar position.
