Results 1 to 5 of 5
    Advice on Lefty DLR break rotor sizing
    Hi Folks,
    I am riding a 02 Jekyll 800 , do anyone know the correct size rotor for the DLR ?
    171 or 178 MM ? The 02 comes with the old 4 bolts hub whick make it very hard to find a right rotor for the Magura Julie.
    If anyone have a 4 bolts magura julie rotor or a lefty 6 bolts hub for sale , may be we can make a deal.
    Thanks all .. a fellow C'dale rider
    The rotor is the standard 6" - 160mm. A bike shop should be able to get you a rotor either fom magura or hayes, they also makes a 4 bolt rotor because they speced them on a jekyll one year
    Magura rotor on DLR
    Tks for the reply , but the 160 mm is on the back , the front is a bigger rotor , I see the number 171 stamped on the rotor , but if anyone is using a 178 mm on a Lefty DLR , I would love to hear your comment.
    Quote Originally Posted by coolatt
    Interesting. Try this, http://www.magura.com/english/frameset/default.htm
    Then contact your Cannondale dealer and if that doesn't work contact magura. Magura has great customer service from my previous experience.
    Click lonnie@magurausa.com if you have a technical problem and if you live in North, Central or South America, Canada or the United States
    I ride therefore I am.
    Reputation: jekyllman's Avatar
    Jul 2003
    Depends on the caliper...
    Quote Originally Posted by PhillyTO
    Hi Folks,
    It's not the DLR that decides the size rotor its the magura juliette front caliper which requires a 171mm, a CODA Expert will also take a 171mm.
    I have a Magura Marta front and rear both 160mm.
    You can usually find a disc on ebay fairly reasonable $15.00.
  1. Cannondale Lefty Max+ compared to TALAS :my $.02
    By dawgcatching in forum Shocks and Suspension
    Last Post: 04-13-2004, 10:39 PM
