Results 1 to 9 of 9
    Mar 2005
    650b wheels on a 2013 Trigger Carbon 1. Possible?
    Hi there,
    Im about to pull a trigger to get the Trigger Carbon 1 2013 bike. But im Just wondering if this frame will take front and rear 650b. I dont want to get the 29er because because im pretty damn short 5'6. Please advise.
    SCALPEL 900 ( Sobe Rep)
    Reputation: nathanbal's Avatar
    if its anything like the jekyll, no. front wheel wont be a problem.
    Mar 2005
    Thanks for your reply. Im about 5'6 I ride 50cm Cannondale road bikes. What do you think i should go for? Small 26 Trigger or Small 29er trigger?
    Reputation: turnerth's Avatar
    Aug 2010
    if possible I would wait for the 650b trigger or scalpel. To my memory they released the trigger mid year, so there is precedent.. and I find it odd they made hardly any changes the the triggers from 2013.. seems like they are trying to keep investment down on those bikes while they work out the 27.5s. but that may just be my wishful thinking.
    Massage Blocks :: The Ultimate Trigger Point System
    Dec 2012
    You are right Trigger 27.5 about March, 2013 will probably not fit the rear wheel.
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    Say the rear wheel did fit is there anything in particular you need to do, or is it a simple case of putting a 27.5 wheel set on instead. I cant really see how you would need to change anything else?
    Also, could you run a normal 27.5 fork off the front instead of the lefty? i can see it changing the geometry so one would have to compensate by running a shorter travel fork.
    All a bit to much changing things if you ask me but just hypothetically speaking.
    OMZ
    OMZ is offline
    The Supermax and headtubes on Trigger 29ers are unique in that each size has it's own length and corresponding Lefty. In other words, the headtube on the small Trigger 29er will be short and fit smaller riders better.
    I am blown away by the Trigger 29er 1 in how well it fits and rides.
    OMZ
    OMZ is offline
    Quote Originally Posted by turnerth View Post
    Trigger 29er in carbon is the change slated for 2014. But yeah, I think there is a 27.5" version of the bike in the works too, but it will probably be considered a 2015 bike...
    Redcoat
    Aug 2013
    Also is it really worth it for a bit of rollover gain?
    Trail Tech: Five reasons not to convert 26in to 650b - BikeRadar
  1. Replies: 5
    Last Post: 08-02-2013, 06:23 AM
  2. 2013 26" Lefty with 650b Wheels?
    By sandyeggo in forum Cannondale
    Last Post: 04-23-2013, 11:35 AM
  3. Replies: 0
    Last Post: 09-22-2012, 08:19 PM
  4. Replies: 0
    Last Post: 09-22-2012, 08:18 PM
  5. Replies: 0
    Last Post: 09-01-2012, 11:19 PM
