Results 1 to 7 of 7
    XCdude
    Reputation: moab63's Avatar
    2X9 SETUP I have a Flash alloy
    Frameset comming, I also have the si bb30 crank and SRam red 9 speed all new. Can I do the duraace front derailler or similar. Iight and cheaper
    thanks
    Feb 2007
    answer is - yes , you can
    I have 2x6 with BB30 Afterburner 386 using a Sram Force front derailleur. It works. It is at it's limit, but it works. Maybe an ultegra triple front derailleur would give you some more flexability?
    XCdude
    Good enough I have ultregas to try
    If that fly's then I'll try the DA.
    Reputation: limba's Avatar
    The Red cassette will clog up if you ride in mud. Cross bikes built with SRAM always have DA 12-27 cassettes.
    Now broadcasting from CO
    Reputation: PAmtbiker's Avatar
    Feb 2005
    Quote Originally Posted by limba
    Yes, or SRAM Force (OG-1070) cassettes. Stay away from Red if you plan on riding off road.
    Brought to you by rocks.
    Red is 10 speed so I don't see how he has a red 9 speed cassette.....unless I"m reading that wrong.
