Results 1 to 34 of 34
    2014 Scalpel Rear Shock Bushing Offset?
    Curious to know if anyone has tried running some offset rear shock bushings on there pre 2017 Scalpels?
    I'm interested in making my 2014 Scalpel geometry a bit more slack. I've already flipped the fork spacer to the bottom...and like the result so far.
    Looks like I could get another degree if I was to replace the Fox CTD stock bushings with some with an offset.
    Thoughts or experiences??
    Mar 2016
    Quote Originally Posted by biffhamilton View Post
    I would give it a try, they are reso cheap. I looked into it when I had a scalpel but didn't change it before I sold it. You could buy one and see if you like half a degree or buy 2 and go the whole hog. Only thing I'm not sure of is how much the bb height changes. You may get a few more pedal strikes.
    Quote Originally Posted by javtec View Post
    Thanks for the info. They are cheap enough. I guess I'll just order a set and try them out. I guess I'm a little jealous of what I've read on the 2017 revamped geometry.
    Oct 2007
    i did put an offset bushing to my 2013 scalpel. Also installed the headtube spacer from top to the bottom part of the steerer tube.
    bushing installed(both holes) to my old rockshox
    level floor. poor picture.
    angle after install(90-20.7 =69.3)
    slacker HT angle, lower BB. that's the immediate effect of it. No rear tire rubbing against the seat tube. Do i feel any difference? any advantage? I have not been riding really aggressive lately compare to when i have not done any "HT slack-hack" to the bike so cannot comment on that yet. And if they are right about the advantage of a 69deg HT, I have a reason not to buy a new bikeyet. not just yet.
    Interesting...thanks for the info!
    I'm surprised that you're able to put a bushing on both ends though. It doesn't look like I have much space for an offset bushing on the back end
    Reputation: xluossa's Avatar
    This is intresting! How much it will lower BB?
    2013 Cannondale scalpel 1 29´er
    2017 SuperX force 1
    www.mckramppi.com
    Oct 2007
    Quote Originally Posted by xluossa View Post
    I didnt do an actual measurement of the BB after install. But the website said that if its a par of bushings on 8mm shock bolt, it supposed to be 10mm lower.
    Mar 2017
    Any updates on how it rides now?
    How close is the rear tyre to the seat tube on full rear compression ?
    I've ordered one of the 6mm (0.75 degrees) bushings for the front mount. (Fox CTD) I didn't bother with one for the rear. Pretty sure only a 10mm will fit. (0.25 degrees) Not worth it IMO.
    The bushing in addition to flipping the spacer from the top to the bottom should improve on slacking the bike out a bit. Not sure if I'll even notice though.....whatever
    Mar 2017
    Hasn't the scalpel got 8mm diameter holes in the bushes at both ends?
    I was of the understanding that the stock bushing holes are centered (no offset)
    6mm diameter - 3mm offset each, ~ 0.75° head angle adjustment.
    8mm diameter - 2mm offset each, ~ 0.5° head angle adjustment.
    10mm diameter - 1mm offset each, ~ 0.25° head angle adjustment.
    A 3mm offset looks like it might be too tight
    Attached Thumbnails Attached Thumbnails 2014 Scalpel Rear Shock Bushing Offset?-offset.jpg
    Mar 2017
    Yes the stock bushes have no offset obviously
    But you have to buy bushes that suit the size (diameter) of your mounting bolts
    So the scalpel has 8mm bolts both ends so you can only fit those bushes
    You can't fit 6 or 10 mm bushes.
    Yea....my bad......I just checked on my order.
    They shipped the 8mm which will produce a 2mm offset.
    I'll have to see if it will fit on the back of the shock. Looks pretty tight. If it will clear safely, I'll order another one
    Oct 2007
    With Fully compressed rear shock, there is still a good half inch clearance between the tire(29x2.35) and the seat tube.
    Quote Originally Posted by eam611 View Post
    It's not the seat tube clearance I was worried about. I was more worried about moving the shock back two millimeters and hitting the linkage.
    Oct 2007
    It has been posted before.. but here is the picture of the rear part of the shock with offset bushing installed. Safe distance With linkage.
    What shock is that? I have the Fox CTD...and I have less clearance than that with the stock bushing.
    Oct 2007
    Monarch RT3
    Mar 2017
    Just to throw another option into the mix, the lefty 29 pbr & xlr can go out to 110mm travel
    More tuning potential, going to look which way the travel is increased if it's longer in de compressed or compressed length as one of them will affect the head angle
    I cut my air piston by 10mm on my pbr90 that came with my f29 when I received a warranty replacement upgrade to the scalpel. Are you saying you can cut 20mm off the air piston to increase to the 110?
    Mar 2017
    Just noticed it was available here
    PROJECT 321 | Products: Cannondale 2015 Carbon Lefty 29er
    Although it just looks like there removing the bump stops above the damper as the axle to crown height is different for each model which also suggests you could trim the damper piston spacer down below as the leg stanchion must have 110mm travel available whilst keeping the axle to crown the same and as you've created extra 10mm of space putting the headset spacer below the headtube you still shouldn't foul the the tyre on the downtube at full travel
    Mar 2017
    Mar 2017
    Did your bushes fit in the rear shock & not foul the linkage
    Quote Originally Posted by Markmtbwales View Post
    Haven't received the bushing yet. Hopefully today. If clearance is good, I'll order one for the front.
    Mar 2017
    I've just gambled & ordered a pair as my new fox DPS shock has no bushes supplied
    Will see how it works out
    2014 Scalpel Rear Shock Bushing Offset?-dsc_4843.jpgHTA now 69.0
    Lefty 29er XLR modified to 110mm, spacers moved to bottom and 2 offset bushings
    Too much snow in town to test this new geometry.
    Mar 2017
    Quote Originally Posted by cannonguy View Post
ID:	1127774HTA now 69.0
    How have you modified the fork to gain 110mm travel?
    Removed the spacers above the damper which would increase the axle to crown measurements or cut the damper air piston down 20mm?
    Got my Xlr 90 off my F29 hardtail to convert for my scalpel
    I don't really want to increase the axle to crown measurement
    Pretty sure you want to cut or change the air piston from 68mm to 48mm
    I don't know. The modification has been performed by the S4 Suspension, the eastern canadian Cannondale service center.
    FYI.....
    I just got off the phone with one of the tech's (Mike) at Project 321. I sent my fork to be rebuilt over the winter (new bearings, race, and damper)
    I also talked with him in regards to shorten my air piston to achieve the 110 travel and slacken the bikes geometry.
    He say's it was common practice to cut the air piston down to 48mm in order to achieve the 110mm of travel on the lefty's. However, with the new 2spring the fork with not work properly with this modification. I believe he said it has to do with the 2spring being shorter than the old bumper stack.... effecting how the negative spring rate performs
    Nov 2006
    Based on some quick research I need a 12.7mm mount kit w 8mm hole. I would like to get the offset setup.
    I have a 13 carbon scalpel w monarch shock.
    Where do I buy this from.
    Mar 2017
    Quote Originally Posted by smackpappy View Post
    https://www.offsetbushings.com
    Mar 2017
    FYI.....
    i have now installed the bushes, fitted the headset spacer underneath the head tube but the fork is still stock 90mm travel from my old F29 Hardtail & head angle is currently still 70' with an axle to crown measurement of 490mm
    (For reference lefty xlr 100 29" = 500mm)
    It's now damper service time so time to increase travel & the axle to crown measure, as my fork is a 2013 model it does not have the 2spring damper so still tempted to cut the damper air piston to 48mm
    will discuss with my suspension technician TF Tuned in the U.K. Before deciding but it will have at least 100mm as per original scalpel.
    Mar 2017
    Has the snow disappeared by you yet & you managed to test the bike?
  1. Replies: 9
    Last Post: 11-15-2016, 12:42 PM
  2. Offset shock bushing in T275a?
    By The Dude in forum Intense
    Last Post: 05-05-2016, 09:19 AM
  3. Jet 9 RDO offset shock bushing
    By 06HokieMTB in forum Niner Bikes
    Last Post: 09-03-2014, 04:44 PM
  4. Replies: 2
    Last Post: 01-04-2012, 03:47 PM
  5. Mach 4 Shock Bushing Question - Offset Bushings OK?
    By Isildur in forum Pivot Cycles
    Last Post: 01-01-2012, 11:50 AM
