Results 1 to 2 of 2
    2013 Scalpel Fork problem?
    I have a 2013 Scalpel 3 alloy, and my front fork is supposed to have 100mm front travel, and tonight I realized it only has 75...
    I let all of the air out of the fork and could not compress it beyond 75mm.
    Any clue what is going on? Is this the infamous needle bearing issue? I thought the new forks were supposed to be updated to not require a reset?
    2011 C-Dale Flash 1 650b
    2013 Scott Genius 930
    2015 Charge Cooker Maxi
    OK so I did do some searching and tried the "let the air out of the fork and ride it around a little bit trick", then fill it back up. Tried itand can still only get about 80-83mm travel. An improvement, but still no-where near where it should be in my opinion......
  1. Replies: 0
    Last Post: 07-15-2013, 09:14 PM
  2. 2013 CAADX Disc Fork/Brake Problem
    By HillegassCX in forum Cyclocross
    Last Post: 07-12-2013, 12:07 PM
  3. Scalpel 2012 | Frame Varnish Problem
    By themuttley in forum Cannondale
    Last Post: 03-31-2013, 03:37 PM
  4. 2013 29er Scalpel 1 or Scalpel 2
    By RyderX in forum Cannondale
    Last Post: 12-16-2012, 11:26 PM
  5. Scalpel cable routing problem
    By codytaylor in forum Cannondale
    Last Post: 08-28-2012, 08:15 PM
