Results 1 to 12 of 12
    Jul 2013
    2012 flash 2 lefty air pressure settings.
    I have a 2012 flash 2 alloy and weigh around 185 and the shop put in 120 lbs of air.. I bumped it up to 150 lbs. anyone have any settings for air and rebound.. Thanks
    Reputation: StumpyElite2010's Avatar
    150 lbs looks good to me - unless you like a divvy fork...
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
    Jul 2013
    Thanks alot less dive and just feels better
    Happy Trails
    Reputation: Scott In MD's Avatar
    Cannondale has an app for that. It's called "Cannondale Tune Your Ride". FYI, for a 185 pound rider with 10 pounds of kit, and 2013 Lefty Alloy 2 with the alloy PBR fork, the app recommends 130 psig and 25mm sag, +/- 2mm.
    Jul 2013
    Quote Originally Posted by Scott In MD View Post
    Thanks.. I will work my way down from 150 to 130..
    Happy Trails
    I'm riding my 2013 fork ~10psig higher than spec, so working down from 150psig will probably dial it in for you. My advice is check the sag before riding and the o-ring position (for full travel) afterwards, and ensure you are using your full travel but still at slightly higher pressure, and you will find the sweet spot.
    Jul 2013
    Thanks.. What's the best way to get the 25mm of sag?..
    Happy Trails
    You need to read your owner's manual.
    There's an o-ring around your fork ... sit on your bike geared up, in a neutral weighting, and then get off very lightly/gently, and measure the travel distance. Maybe make a few trials ... don't add compression from bouncing on or off.
    The distance of compression travel ...That's sag.
    Reputation: thatdrewguy's Avatar
    Not on the OP's 2012 fork. To check sag I just note where the handlebar hits against the wall unloaded and then when I get my weight on the bike.
    Jul 2013
    Thanks but to get the proper sag you have to let air out of the fork right?..
    Quote Originally Posted by Jamis View Post
    Unless of course you don't have enough air and there's already too much sag, right? From my experience the Cannondale app gave me pressures too low and I had too much sag so I increased pressure until I got the minimum amount of sag.
    Jul 2013
    Yes that's what I was getting.. I am running 150 now with minimal sag a little stiff but much better.. Thanks alot for the help.. I mean a perfect evening to ride right..2012 flash 2 lefty air pressure settings.-image.jpg
  1. 2013 Lefty on 2012 Flash Carbon 2 frame?
    By dardeca in forum Cannondale
    Last Post: 09-13-2012, 03:32 PM
  2. Pressure Settings for Tallboy Rear Shock????
    By bowler1 in forum 29er Bikes
    Last Post: 07-04-2012, 05:13 AM
  3. Jet 9 pressure settings recommendations
    By TunicaTrails in forum Niner Bikes
    Last Post: 06-05-2011, 03:00 AM
  4. your air pressure settings for 2010 Boxxer World Cup ?
    By Freeride777 in forum Shocks and Suspension
    Last Post: 05-24-2011, 01:38 PM
  5. Reba 4 Clydes-Max Pressure & Other Settings
    By tenbsmith in forum Clydesdales/Tall Riders
    Last Post: 05-16-2011, 08:18 AM
