Page 2 of 2 FirstFirst 12
Results 51 to 54 of 54
  1. #51
    Feb 2012
    Quote Originally Posted by N2B View Post
    Can a 2013 hybrid 29er alloy 90mm be changed to 100mm ?!
    bump n2b's question im curious about this one as well
    thanks
  2. #52
    Hi Mendon (or anyone that knows the answer),
    I know this is an old post but I just did the mod. When you mention on changing the air volume, do you mean add more or remove the volume reducer and then add more?
    Quote Originally Posted by MendonCycleSmith View Post
    Yes, the A to C would increase. The top air piston on the damper has a long throat on it, every bit up to 20 mm you cut off will result in concurrent A to C and travel increases.
    Note that if you don't also change air volume commensurately, it will change how the fork feels. Not a bad thing really, the standard volume reduction for 29ers makes the forks feel too progressive for me personally. I run them travel reduced, with effectively, 26" wheel air volume.
  3. #53
  4. #54
    Feb 2005
    What ^he^ said....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
  1. 2011 Epic 29er with Lefty
    By TurnerConvert in forum Specialized
    Last Post: 09-21-2011, 06:21 PM
  2. Replies: 0
    Last Post: 07-21-2011, 05:59 AM
  3. 2011 PBR 29er internals in a 2010 DLR 29er Lefty?
    By brentos in forum Cannondale
    Last Post: 04-16-2011, 10:55 AM
  4. Replies: 0
    Last Post: 04-09-2011, 01:45 PM
  5. Difference between 2011 Flash 29er 2+3 lefty
    By uwprunner in forum Cannondale
    Last Post: 10-22-2010, 09:26 AM
