Results 1 to 11 of 11
    Reputation: rumshcawheely's Avatar
    2011 xlr 29" & 26"
    Are the internals the same in 26 and the 29 XLR?
    The 29er XLR uses three spacers on the standard Ultra120 to get its 90mm of travel.
    YB1
    YB1 is offline
    Whats that KF272 part do?
    Emory Kalahari Kruiser
    Quote Originally Posted by YB1 View Post
    Thats the Compression Piston, it goes inside the shaft and you preload the spring whit the Air Piston.
    This piston works when the oil expands whit temperature.
    Feb 2005
    Quote Originally Posted by rumshcawheely View Post
    Yes.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    The XLR dampers have different part numbers for the 29er vs 26er, Craig will know if they're really just the same though. The Solo Air upper seal and volume reducers appear to be different lengths as well. The main difference is the (external) outer lower assembly for the 29er is from the 120 and the 26er is the 100. This info is from the blown up diagrams in the Lefty manual, Craig's knowledge will usually trump that though
    BTW Craig, Drew got me fixed up....PM me if you want, it's interesting....
    Thanks guys. I'll come up with more questions soon. It's about time to get back on the saddle again! And with that comes some maitainance and upgrades.
    Feb 2005
    Quote Originally Posted by trauma-md View Post
    Same dampers. Different #'s are just to allow them to stock them all set up for one wheel or the other.
    XLR dampers have different hardware internally for the XLR unit, but either damper can be made to work for either control unit with the addition or removal of said hardware.....
    I'll bite. PM me, what'd he do for ya?
    - FrostyStruthers
    Whoa, back that horse up...
    It all depends what forks you are talking about. There are XLR's that use the 140mm damper and there are XLR's that use the 100mm damper. Need a few more specifics about the forks you are questioning.
    XLR 140, XLR 120, XLR 90 (29er) all use the same damper.
    XLR100 is different...and it can be 29er'd
    Feb 2005
    Quote Originally Posted by Headshok'r View Post
    Very true, I was simply speaking to the difference between XLR and PBR dampers. There are indeed different dampers in those two forks.
    Thanks for clarifying!
    - FrostyStruthers
    Basically I was just thinking about adding a 29er to the mix. Wondering if I could still use my older lefty on a new 29er. I went to the geometry sheets on the older 29 frames when all forks were 110 with a spacer vs. the geometry of the current 29 frames. As I see it the steepened up the head tube angle to make up for the fact the the new 29 lefty has a longer upper. Therefore, if I got a new frame and put a 2010 lefty on it, it would jack up the feel of the bike do to the head tube angle changing. The question I started out with was meant to say are the xlr90 and xlr100 internals the same. I know the the xlr90 fork has a longer upper than the xlr100, but I just want know if the internals are the same.
  1. 2011 "Official" Saturday SoMo Shuttle Thread
    By abcnorte in forum Arizona
    Last Post: 12-08-2011, 11:00 PM
  2. Motobecane Fantom 29 - 2010 vs 2011 (now "Trail")
    By fromallsides in forum Motobecane
    Last Post: 04-13-2011, 06:25 PM
  3. Replies: 0
    Last Post: 12-27-2010, 12:26 PM
  4. Replies: 2
    Last Post: 02-26-2009, 10:44 AM
  5. "Kliane" "Klein" "Quasi Moto" "Paul"
    By stan4bikes in forum Vintage, Retro, Classic
    Last Post: 08-20-2007, 03:36 AM
