Results 1 to 3 of 3
    Aug 2005
    2011 Scalpel single speed-able?
    the rear is pivotless, so the BB to rear hub will stay almost the same, so it is single speedable (with an ENO hub, or finding the right "magic gears")
    I'm not asking if this is a GOOD idea, I dont think it is, and that is not what this bike is made for, just wondering if it COULD be done
    good ski/bike deals at www.mntlion.com
    My life is better than your vacation.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    You would need a spring loaded tension device. You used the right word:
    Quote Originally Posted by mntlion
    Almost, but not quite. There is no physical pivot between the BB and rear wheel but the flex makes the distance between the two points change as if there was a pivot somewhere along the chainstays, so there will be a bit of chain tension change through the travel...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Aug 2005
    thanks, as I said it was more an "I wonder" then an "I want to"
