Results 1 to 7 of 7
    Reputation: GTIgor's Avatar
    Nov 2007
    2011 Jekyll + Fox36 1.1/8" or tapared
    Is the possible?
    I've heard they are designed to run 1.5 integrated headsets, are there headsets on the market which would fit 1 1/8 steer tube (or a tapered one) in this frame?
    Thinking of buying a frame separately, so finding a 1.5 Fox 32 wouldn't be possible (and not so fond of 32's chassis - would 1.5 improve the stiffness radically - doubt that!).
    Reputation: Duncan1104's Avatar
    Quote Originally Posted by GTIgor View Post
    Is the possible?
    Yeah, you can run a tapered 36 on the Jeykll. Mark Weir and a few other pros have 36's up front.
    Nov 2007
    Quote Originally Posted by Duncan1104 View Post
    hm... wonder what upper headsets they are using, its a integrated 1.5" - pretty rare one
    Reputation: chick0's Avatar
    Without ever comparing a 1.5" with a 1 1/8 directly myself, i can't say for sure if you would notice the extra stiffness, but i have read in various places that their is a detectable stiffness advantage using a 1.5" steerer ( especially when using 150mm forks).
    This Review talks about the stiffer feel of the 1.5",
    Cannondale Jekyll 3 Review - BikeRadar
    It is possible to find some 1.5"' 32's on the market, i saw these for sale the other day.
    Fox Suspension Forks - Merlin Cycles
    This is the reducer headset you need to run a 1 1/8 steer if you take that route ( KP058)
    Headset reduction to 1 1 / 8 " - Dr. Cannondale
    To run a tapered fork, i guess you could mix the top bearing of a KP058 headset with 1.5" bottom bearing of the KP119 headset.
    Headset 1.5 - Dr. Cannondale
    PM me your email address and i will send you a PDF file i have of all Jekyll 2011 frame parts, that's where i have taken the Cannondale parts codes from.
    I'm about to through a similar situation as you, building a Jekyll frame set up from scratch, as i have been told im getting a carbon Jekyll frame to replace my cracked carbon Rize under warranty, so i have been working over what parts will and will not be transferable over from my RIze in the last few days.
    Edit;
    If you are in North America, this site might be more useful for what you need, as Dr.Cannondale is based in Germany.
    Cannondale Experts - CannondaleExperts.com
    Sorry for resurrecting an old thread, but I've also just received a Jekyll frame as a warranty replacement. Can you let me know what headset you opted for in the end? I'm looking at the FSA Orbit DL 1.5R but wondered what else might work.
    Cheers
    I'm running a tapered fork (Rock Shox Revelation World Cup) and using what chick0 mentioned: the bottom of the KP119 and the top of the KP058.
    Excellent thanks. qwertycycles.co.uk have suggested something similar too. My RLT's have a 1.5" seal / race already on them - I'm assuming the KP119 is just a seal / race and bearing? If so I'll prob just buy a bearing for the lower and buy a KP058 for the upper.
    Cheers
  1. 2011 Jekyll with Lefty !
    By chick0 in forum Cannondale
    Last Post: 08-06-2011, 11:12 PM
  2. 2011 Jekyll
    By smilycook in forum Cannondale
    Last Post: 11-03-2010, 04:03 PM
  3. Some 2011 Jekyll ??
    By hags707 in forum Cannondale
    Last Post: 10-22-2010, 06:31 AM
  4. Jekyll 2011 info where?
    By Filthy in forum Cannondale
    Last Post: 09-07-2010, 04:49 PM
  5. 2006 Fox36 Talas VS 2008 Fox36 Talas
    By Spartacus Rex in forum Shocks and Suspension
    Last Post: 05-30-2008, 05:31 PM
