Results 1 to 13 of 13
    2011 Flash Carbon 29'ER Weights
    Hi,
    I am super interested to know the stock weights on these bikes and also the weights that riders have managed to get them down to, specs as well if possible.
    Flash 1 =
    Flash 2 =
    Flash 3 =
    JP
    Dec 2010
    i have the 2011 flash carbon 3. the bike shop weighed it and it was 24 lbs even. i have not done much upgrading to it besides a carbon seat post but i'm sure the flash 3 is capable of losing quite a bit of weight.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    I had a 2010 , stock 10kg reduced to 8,1
    Reputation: Spinning Lizard's Avatar
    Have a 2011 Flash Carbon 1 - 18.9lbs, cant remember stock weight.
    R1 Brakes (160/140)
    Truvativ Carbon Noir Bar
    I9 with Crest Wheels
    SRAM XX Cassette, R Der, Shifters
    Thomson Masterpiece Post
    WTB Silverado Ti Saddle
    Hollowgram crank with XX rings
    X9 F Der ( have the XX was waiting for spring to install)
    Time ATAC carbon titan pedals
    Sep 2004
    flash carbon 29 - 3 = 10.3 kg out of de box, without pedals
    2011 Flash 29'r Carbon 2, out of the box, no pedals:
    just under 23 pounds.
    I don't know much about carbon so will be trying to break it before the CCP100. Probably won't get any lighter, put Titec J-bars on, done weighing things. Rear derailler hanger is a bit delicate. Lefty PBR ROCKS!
    Didn't think carbon frame would be so....FAST.
    bike ON
    bob
    red-haze
    The more I know the more I know I don't know.
    Let the bike ride the trail, you ride the bike.
    Look where you want to go, not where you don't want to go.
    I have the flash 3 at 24 pounds even and the flash 2 at 22.3 using the park scale both are medium frames.
    My LargeWhite/Red Aluminum Flash 29'er Single Speed is 21 lbs.
    Lefty 29er PBR Frok, Bontrager XXX seat post & Riser Bar, Hope Rear Hub, Stans 355 hoops, Avid Juicy 7 Brakes, Schwalbe Racing Ralphs (2.4 front, 2.25 rear) running tubeless, FSA Afterburner BB30 Crank, Crank Brothers Egg Beater SL Pedals, Brass Bell, Top Flite XC Gel Seat.
    Waiting for Godot
    Reputation: OilcanRacer's Avatar
    how heavy is just the frame?
    Out riding, leave a message
    Quote Originally Posted by OilcanRacer
    Which frame, my Aluminum (doubt you mean this one), the carbon frame, or the Hi-Mod Carbon Frame? They have made all three.
    Waiting for Godot
    sorry the two carbon frames?
    FIRENZE rulez !!
    i had a 2010 M size not HI-MOD frame , 1130 g
    (at memory, can be maybe 1150 but not so far from what i wrote ...)
    Reputation: Chain-L's Avatar
    my 2011 Flash carbon 29er 2 stock standard with bottle cages, pedals 2x CO2 bombs and garmin mount. 10.48 kg
