2010 rz120 rear tri play ??
I have a as new pre owned rz120,i was setting up the bike the other day and noticed a slight bit of play in the rear triangle.i'm not sure if it is coming from the shimano rear hub or the rear triangle....has anyone had this issues with there rz ??
thx !!
Check the 2 pivot points (especially) at the very back by the rear brake. The 2010 RZ's (at least both that I own) had the exact same problem and those bolts not torqued properly from the factory, actually not even close. My LBS took care of the problem in about 5 minutes, and upon further inspection, NONE of the bolts on the entire bike were torqued correctly. Just because a bike comes from the factory almost completely assembled, that does not mean that the guy who put it together was paying any attention, or really cared...
I highly recommend that you get that checked before you either trash your bearings, or break something and get hurt...I am not saying that this is your specific problem, but it was mine.
By Keninshiro in forum Cannondale
Last Post: 11-01-2011, 09:25 AM
By GavinXX in forum Cannondale
Last Post: 01-12-2011, 03:09 PM
By dapozer in forum Cannondale
Last Post: 01-07-2011, 10:48 AM
By Roasted in forum Shocks and Suspension
Last Post: 08-08-2010, 11:20 AM
By BBW in forum Shocks and Suspension
Last Post: 12-27-2009, 04:14 PM
- You may not post replies
- You may not edit your posts
Forum Rules
