Results 1 to 3 of 3
    2009 Scalpel Front Derailleur
    I'm in the process of swapping parts from a Caffeine frame to an aluminum Scalpel. The Caffeine has a 34.9 seat tube vs. 31.8 for the Scalpel. I have to either get a shim or a new front derailleur. If I decide to get a new derailleur it seems I can get a better deal on a low clamp version as opposed to the high clamp mount found on the stock Scalpel.
    It appears a low clamp FD would fit without problems. Is there any reason not to use a low clamp FD on the Scalpel?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    It will work fine. The stock specs use a high clamp because they're usually a tad lighter. But what derailleur are you looking to get? many are one size only and are provided with shims anyway...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Dan,
    Thanks for the confirmation. Since the current derailleur came with the Caffeine, I don't have the shim that's normally shipped with the derailleur when purchased separately. I'm loath to spend more on shipping than the shim so I may splurge and pickup a discounted X9 or XT.
    I thought a LBS would have some shims lying around from new bike setups but I was unable to source one locally.
  1. Which front-derailleur for 2x9 scalpel carbon
    By de Ron in forum Cannondale
    Last Post: 06-07-2011, 07:46 AM
  2. Replies: 1
    Last Post: 03-11-2010, 08:55 AM
  3. Top Swing Front Derailleur on a '08 Scalpel?
    By jasonsheep in forum Cannondale
    Last Post: 02-23-2009, 06:06 PM
  4. Sram front derailleur on 2006 team scalpel?
    By scalpel2007 in forum Cannondale
    Last Post: 05-17-2008, 02:15 PM
  5. What size front derailleur for scalpel?
    By SocalSuperhero in forum Cannondale
    Last Post: 12-24-2005, 06:27 PM
