Results 1 to 35 of 35
    2008 Scalpel Team Replica
    Found a 2008 Scalpel Team Replica @ my local Cannondale dealer. I currently own a Scalpel 3000 and was wondering if the new Carbon Frame is as durable as my 3000 frame.
    I cracked several Campy Record seatpost so Im kinda leary about a Carbon Fiber frame.
    Im ready to pull the trigger , any tips, feedbacks and advise on the 08 frames greatly appreciated.
    thanks
    I have raced this bike three times over some nasty terrain and I am a 210lb clyde. No issues or complaints here. The warranty on the frame is for life too.
    Bryan
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    i love this frame... so in your pants i will buy it
    I've swapped my Rush for one and love it! Like it says above, warranty for life, can't complain about that.
    Reputation: nathanbal's Avatar
    Quote Originally Posted by DICKDOG
    apologies to the TS for the hijack, but what were the main differences between the new scalpel and the rush? was it an alu or carbon rush?
    guys-
    thanks for the feedbacks. Im 90% there...the taxes alone are driving me nuts
    I have 4 Cannondales and Im confident about their warranty- the only thing that worries me is the "crash warranty" --hope the Carbon frame holds well in that situation
    Correct me if Im wrong but are the newer Carbon frames run a little smaller than the previous models..?? it feels that way..
    thanks eliflap- I'll look you up when it comes to upgrades..love your bike and its what motivated me to go this route
    does it make a difference between the Fox RP23 VS the DT Swiss ?
    thanks again-
    FIRENZE rulez !!
    weight is a difefrence , DT lighter than 80 gr
    but Fox is more tuneable with more adjustement
    it works at higher pressure than DT
    i have now on ebay a 2008 fox or in the ads too
    Reputation: rumshcawheely's Avatar
    [QUOTE=spartan23]guys-
    I've had nothing but good experience with cdale and their warranty. As for carbon and crashing, the stuff is really, really strong. I purchased a Taurine that was a demo and it looks like someone really treated it like a demo bike. It's got a couple gouges in it but this thing has been ridden hard for about year now and the gouges show no signs of change. The rep told me that if their ever was a problem with it, he'd take care of it.
    Who on earth built that with the spoke protector and reflectors?!?!
    It's cruel.
    I'd suggest you buy it just to set it free!
    thanks for the encouraging replies guys
    nicholas- they are definitely coming off but cant wait to add the basket up front .
    I think its required for bike shops to have the safety equipment on..(must be a California thing) ....then our Governator wants $540 worth of taxes
    Hi Spartan,
    My first frame was one of the two European frames that 'broke' at the chainstays. I was a bit scared with my new frame but after a wild Dolomiti-Transalp a few weeks ago with some extreme downhills I am back in love with the frame! It worked out very well. Now I am going for the Lefty-tuning at 88+. Uphill it's a monster, downhill it finds it way for you...
    Good Luck!
    triplejee- yes, I heard the 1st batch of productions were having issues. I was told by the dealer that the newer frames are solid.
    I have a friend that is encouraging me to try the ibis mojo. I tried the Ellsworth Truth several weekends ago @ a local trail (Demo day hosted by summit bikes), gotta admit, love the power transfer of the Ellsworth Truth.
    Anybody tried the ibis or ellsworth against our beloved Scalpel?
    thanks again.
    Ok, I ended up with the bike...we weighed the bike with flat pedals and all the funky reflectors @ 22.97 lbs. (not bad)
    last question to Scalpel owners...what packet (manuals etc) came with the bike? Does it come with the adhesive protectors and chain guards?
    thanks to all that replied
    My frame had in the box:
    1 x Cannondale owners manual (read carefully)
    1 x 3M Protective strip pack
    8 x plastic cable housing guides
    1 x BB Cable guide
    3 x Cable stops (to fit in frame cable guides)
    No Fox set up guide
    No chainstay protector, this is already fitted. I also use a Lizzard Skin Slapsok
    The Downtube protector is also prefitted.
    Sag must be betweem 8mm and 10mm. That is around 60psi for me!! It's very low. I suggest you invest in a new gauge for your shock pump. One that reads to 100 or 150 psi is ideal to get the fine adjust, or buy a shock pumpwith a digital gauge.
    I too have switched from a 2yr old alloy Rush 3000 to the Scalpel Carbon 1. The carbon bike is awesome! Its a lot stiffer although not that much lighters than the alloy bikes. Yes there is a crash disclaimer but that is also for the alloy bikes. Cannondale now also have a terrain definition scale that ranges from 1-5.
    1 - basically a road bike
    2 is basically a cyclocross bike
    3 is essentially your XC and MArathon bikes. Warranty is for the duration of the life of the original owner.When you die, you take the warranty with you.. thats why I love Cannondale. I can take a bit of my dale to heaven with me,
    4 is the AM kind of bikes
    5 is the severe riding kind of bikes. These now have a 3yr warranty.
    Apparently they have made these changes because some [word removed] people were going DH racing with XC Hardtails and doing jumps on Scalpels, the bikes broke and Cannondale had to replace them under warranty!
    FIRENZE rulez !!
    PSI difference :
    60 psi with a FOX RP 23 ???
    i think it's too low !!! it works at more high pressures , as 140 psi for example
    60 is correct for a DT Carbon shock , that has a littler chamber ...
    i use 70-80 on my DT
    brad-thanks for the list..mine didnt come with all of that.
    1) lefty manual
    2) Scalpel 100 manual
    3)Cannondale Handbook
    4) missing XC3 cap (round cap that covers the Si stem) they say its supposed to be like that
    Tool
    Reputation: Pedalphile's Avatar
    Quote Originally Posted by eliflap
    PSI difference :
    If the diameter of the piston (chamber) is smaller, it would require more pressure, not less. PRESSURE*AREA=Force. Keep in mind that the chainstays on the Scalpel provide suspension compression resistance, and thus the low shock air pressure.
    From the Scalpel 100 Owner's Manual Supplement:
    "The living hinge seat and chainstays work in conjunction with the rear shock and provide some of the spring rate. This integrated spring force results in riders requiring much less air pressure than normal."
    -Pete
    FIRENZE rulez !!
    yes i know the manual supplement ... but i use only a DT on my bike
    my spare , new, unused , RP23 was sold yesterday on ebay ...so i never checked the real difference from these shocks at work in same frame ...
    8-10 mm of correct sag are in PSI for a 70 kg rider for the RP 23 ?
    Tool
    I weigh in at 79.3kg and have my RP23 inflated to 26psi to achieve 8-10mm sag on the Large size Scalpel frame. I imagine the required psi would be linear as a function of rider weight on the same size frame, but possibly different on different size frames as one would assume the rear triangle has a different stiffness on each size frame. There's no point in guessing when it's so easy to measure the sag with the shock's o-ring, though.
    -Pete
    Edit: Brad's numbers are likely correct below. I don't have an accurate in-pump guage, and it would appear my attempt to measure the pressure with a stand-alone guage let out a considerable amount of air. Although I can't tell you exactly what pressure I'm running to achieve 8mm sag, it's at least 50psi.
    Spartan,
    The bike is shipped with all those goodies. Your LBS shop mechanic should exercise more caution with the goodies in the box. Everything is in there, including the top cap for the stem because that is shipped with the stem. It is not a separate item. Take it up with them and insist they replace it.
    For a whole bike there should be:
    Lefty manual
    Fox manual
    Cannondale warranty card
    Cannondales Owners manual
    Split cable guides (8off)
    Cable Housing stops (3Off; 1 for front derailleur and 2 for rear,on right side seat stay)
    XC3 Stem steerer top cap
    seat collar clamp
    Cable hooks for Lefty (2off)
    Oil seal (1 off)(this will be assembled on the bike if it's on theshop floor)
    Headshok Si Heaset bearings (2off)
    Eliflap,
    I weigh 77kg, ride a medium and to achieve 8mm sag the pressure in the RP23 is 66psi. to achieve 9mm it is 60psi and 10mm it is 56psi. This will change once the shock is run in. Not the upper values somuch but the range will decrease.
    The leaf spring does add a lot of spring rate hence the low air pressure. The DT shock is also a High pressure unit. On any other bike the Dt and Fox would work at similar pressures.
    Also because of the leaf spring, the rider must set up the rebound properly. I have found that Fox rear suspension units rebound damping only works in the last two clicks. I use mine 2 click out from max rebound damping.
    Quote Originally Posted by spartan23
    1) lefty manual
    The missing cap creates a great place to put you food wrappers!
    Tool
    Quote Originally Posted by rumshcawheely
    I turned mine into a bong: the 420 head tube
    -Pete
    Tool
    I've got your fun fact for the day (it's actually quite useful, though):
    The outside diameter of the open end of the valve cap on the Fox RP23 is exactly 8mm, which, coincidentally, is the minimum recommended sag for the rear end of the Scalpel. Very convenient if you ask me.
    Do, however, be careful not to touch the cap to the shock piston as any scratches can compromise the function and/or lengevity of the shock.
    -Pete
    I can barely get my mouth around it.
    Quote Originally Posted by Pedalphile
    -Pete
    thanks for the pointer as I have been trying to figure out how long 8-10mm is
    so its the "cap" and not the rp23 itself right?
    Tool
    At the risk of replying to sarcasm: Yes - it's the outside diameter of the open end of the cap, not the RP23 itself.
    That's what makes it so convenient. If you're playing with the air pressure you're going to have the cap off anyway, and it can easily be held close to the gap between the shock body and the o-ring for comparison. It's a lot easier that trying to eyeball with a tape measure, and not everyone has a set of measuring calipers (certainly not on the trail).
    -Pete
    excellent tip!
    -Pete
    Pete-
    Thanks for the tip as I seriously wasnt sure if the sag was @ 8-10mm. It turned out my RP23 was overinfalted.
    Tool
    Spartan,
    NP. Enjoy the softer ride. With the Scalpel's design and low pressure requirement for the shock, a reletively small pressure difference in the 23 can make a big difference in the ride.
    Cherers,
    Pete
    Spartan,
    Cherers,
    Pete
    I can feel the difference already- I was wondering why the new Scalpel felt so stiff/ firm.
    BTW- my technician has a digital scale measure and measured the cap @ -8.46mm to be exact .
    I tried locking out the RP23 and still bobs is that normal?
    thanks again Pete-
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    thanks again Pete-
    There is no complete lock-out on the RP23, the lever changes it from full open (no plateform, good for downhills) to Pro-Pedal (with plateform). When on Pro-Pedal, you can pull the knob, choose between the three levels and push it down again... Play with the 3 settings and see if it helps...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Quote Originally Posted by Dan Gerous
    There is no complete lock-out on the RP23, the lever changes it from full open (no plateform, good for downhills) to Pro-Pedal (with plateform, when on Pro=Pedal, you can pull the knob and choose between the three levels)... Play with the 3 settings and see if it helps...
    This is what happens when I dont have the manual..thanks Dan, I'll check the 3 levels out.
    LA CHÈVRE
    Here's the manual.
    Tool
    I can feel the difference already- I was wondering why the new Scalpel felt so stiff/ firm. I tried locking out the RP23 and still bobs is that normal?
    Dan covered it well above.
    In addition, your weight/riding style and terrain may dictate that you lean more towards 8mm sag than 10mm. I don't see any issue with less than 8mm sag so long as it gives you the suspension response you're looking for. Definitely play with the propedal settings first, and don't forget the rebound settings.....for me, the rebound control doesn't seem to have much effect until the last two or three clicks. Six clicks from undamped seems to be the right setting for me.
    -Pete
    Dan/ Pete- I learned something new each day...thanks for the manual and tips. I was able to try different settings for the 1st time..so far I like # 3 but we'll see how it goes offroad.
    Carbon Scalpel is starting to feel like I have a 5" travel (on #1)
