Results 1 to 20 of 20
    Cyclist of Borg
    Reputation: Locutus's Avatar
    2007 F1 Finished
    All done
    Frame $300
    Fork $35
    Der Hanger- Red Anodized $30.49
    Wheels- Hope Pro 2, Mavic 823, DT Comps w/Red Nips $644.38
    Rear Der-XTR 970 $76.94
    Headset Bearings $25
    CNC Spacers-Red Anodized $14.65
    Cassette-SRAM Redwin $60
    Seat Clamp- Hope Red Anodized $25
    Chain Ring Bolts- KCNC Red Anodized $14.95
    Pulleys- Token Red Anodized $49.99
    Boot $22.70
    Water Bottle Bolts- Red Anodized $13.50
    Front Der- XTR 971 $75
    Brakes-Avid Code White w/Red Anodized Straitline Levers $299.99
    Front disc and adapter- Avid 203mm G3 $50.19
    Brake Levers- Red Straitline $61.39
    Cable end crimps-Red Anodized $7.21
    Stem-Hope Red Anodized $97.98
    Crankset- XTR 970 $350
    Bottom Bracket- Hope Ceramic Red Anodized $119.07
    Bars- Easton EA70 Monkey Bars $58.11
    Grips-Portland Design Red Anodized $36.35
    Bar end plugs- Hope Red Anodized $22.64
    Seatpost-Thomson Elite Black $70.87
    Saddle WTB Speed V Black/Red $41.99
    Housings
    Pedals C Bros Eggbeater Ti $157.72
    Shifters XTR 970 $169.99
    Tires Maxxis Crossmark $106
    Chain XTR 7701 $32.90
    Stans Stems $17.90
    $3087.87
    Resistance is to high a gear.. i mean futile
    Mar 2006
    You forgot the hubs, you can add another $300 to the total
    Looks nice
    Cyclist of Borg
    Quote Originally Posted by jiar577
    Looks nice
    that price includes hubs, rims, spokes and nips. built by Mendon
    Expensive. But I'm sure it's worth every penny. It's a lot more satisfying when you build your own bike rather than just buying it as a whole. Looks great... let us know how it rides.
    Awesome Dude!!!!
    Cyclist of Borg
    ... and if we just ...
    Quote Originally Posted by mizzou
    it is VERY satisfying. Knowing i have what i want and also getting everything as cheap as possible. I just nabbed [today] an XTR 970 crankset NIB for $350
    Reputation: dyusem's Avatar
    WOW!!! That will be one sweet ride and is as beautiful of a bike that I've seen...nice work.
    Care to build one for me?
    Reputation: Duncan1104's Avatar
    Those are sweet grips. Aren't Codes a little overkill for that bike?
    Cyclist of Borg
    Quote Originally Posted by Duncan1104
    Maybe My computer geekiness sometimes bleeds over to cycling. I believe you can never have to much power
    Cyclist of Borg
    just bought the remaining parts and updated the OP
    Will update when its done
    HT Trailbike
    Looks like your building a solid trail bike. Nice to see you're not building an anorexic HT like everyone else. But all of those burly parts you put there, you'll probably going to be pushing that frame to it's limit. If that's an optimo frame, its design to be XC and race. Also, you might want to check if the fork can handle a big rotor. That looks like a 185mm rotor. I have 160 F/R codes on my trail bike and that brakes have too much power. It's nice to have but I'm running lyrik fork and 20mm axle. You have QR and Headshok. Might not be safe.
    Run a fat tire and it would look nice. Post back with a complete bike.
    Cyclist of Borg
    Just a quick update
    Waiting on tires and a powerlink. Then cable it and im done
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    That F1 frame is unbelievably LIGHT...too bad Cannondale only made it for one year.
    You spent a lot of dough...but worth every penny spent!
    I spent the same as you did, and wound-up with a 19.8lbs XC rocket(see profile).
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Quote Originally Posted by Zachariah
    Not sure I follow. Is there a difference between this F1 and other Caffeine frames? Isn't it the same frame whether it is an F1, F2, F3? And weren't they made for 07, 08, 09?
    Cyclist of Borg
    All finished. Final pics are up
    Nor­wegr
    Reputation: Vegard's Avatar
    Those portland grips are nice, but they pretty much nullify the monkey bar due to their weight.
    I run the same bar\grip setup and I'll be replacing mine with bontrager xlite grips till I can find lighter lock-ons.
    Cyclist of Borg
    thanks. i like the grips also. i was not going for light weight.
    It did come a hair under 25.5 pounds
    Cyclist of Borg
    bump
    This bike is for sale in the classifieds
    where did you find an 07 F1 frame?
    Cyclist of Borg
    i got it off of eBay in Feb 08
