Results 1 to 5 of 5
    2007 Cannondale F5 Bottom Bracket Size?
    I just recently purchased a 2007 F5 and was wondering if anyone knew the bottom bracket size? Also are the Race Face Atlas FR cranks compatible with this frame?
    yorkshire mud monkey
    Reputation: sausagedog's Avatar
    as steve said "As long as the rotor/rivets clears the fork, a miss is as good as a mile"
    Yeah thanks, I went to that and all it has is the part number. I googled the part number and found it on shimano and it has a picture, but no specs. In the picture it says 68 is that supposed to be 68mm?
    http://bike.shimano.com/publish/cont...26.-type-.html
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    The Atlas should fit fine given you have the supplied spacers. As for the size of the BB, I'm pretty sure it's 68mm wide. You can verify by measuring the width of the frame's bottom bracket shell... It will be either 68mm or 73mm.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Ok I'll measure it, Thanks.
