Results 1 to 2 of 2
    Reputation: valiant1974's Avatar
    New question here. 2006 Rush 400 question...
    I'm thinking about buying a friend's 2006 Rush 400. The bike has the stock Rock Shox Recon 327 front fork with FSA headset.
    I assume this bike will work with a Lefty as the frame should be the same as the higher model Rush frames. Right?
    Can anyone confirm that this bike will work with a Cannondale Si headset and Lefty fork?
    Thank you!
    '15 Niner RLT 9
    '13 Pugsley Necromancer
    '13 Bad Boy 5
    '09 F29 2
    '08 Rush SL 5Z (650b)
    '00 F2000SL
    Mar 2006
    Yes it'll work. Just remove the headset adapter and you're good to go.
    The 400 was bottom of the line but had the same frame as the most expensive Rush Replica that year.
