Results 1 to 2 of 2
Thread: 2004 Gemini
    2004 Gemini
    I'm thinking of picking up a used 04 Gemini 3000 frame. Anyone know of any issues with the frame for this year? I know it has the 12mm rear end but what is the spacing on the rear? is it 150mm or 135mm. Just wondering if I should wait for a newer one to pop up somewhere...
    Here's the spec:
    http://www.cannondale.com/bikes/04/cusa/model-4VG3.html
    The 3000 should be 135mm spacing in the rear.
    I have a 05 Gemini and it's rated for a 570mm axle to crown height. There are some older Gemini that's only rated for 530 mm axle to crown height. I don't know what the 04 is rated at. Here's the tech doc. You can check the frame number to figure out the 04 rating.
    http://www.cannondale.com/asset/iu_f...echnote_en.pdf
    Gemini is a versatile frameset.
