Results 1 to 5 of 5
    2001 jekyll rear wheel
    I have to replace my 2001 jekyll 3000 rear wheel as it's no longer viable to repair. It's a coda competition could anyone recommened a cheapish new wheel. I've tried my dt swiss wheel off my flash so it obviously is not standard spacing as it doesn't fit
    Any help would be appreciated
    Feb 2005
    If you're trying to use the existing Coda brakes, yeah, the spacing on them was different.
    The rear end is still 135 mm though, so any MTB wheel will fit fine. You'll just need to get a new brake too, not a bad thing, as the 4 bolt disc and Coda brake are a bit of a white elephant anyway....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    No the coda brakes came off straight away and replaced with hope 4 pots. This seems a bit extreme to replace the wheel and the whole braking system. Can i buy an adapter to fit a new wheel that converts a 6 bolt to a 4 bolt to use or do i still need spacers or something. I never had a problem in 10 years but i can't get parts for it and didn't know what to replace it with
    Feb 2005
    So you have Hope brakes, but still the Coda 141/171 rotors? Or did you go to 160's f+r when you got them?
    IIRC, the Coda set up positioned the rotor in farther, so you'd need to put spacers behind the rotor to make it work with a 6 bolt wheel.
    As long as your rotors are 160, just buy a new wheel and replace the rotor too, then simply re-space the rotor.
    - FrostyStruthers
    Sorry been busy thanks for the info I've got the hope disc which is 160, so i'll buy the wheel and a new rotor
  1. Lefty Max 130 on a 2001 Jekyll?
    By velcipede in forum Cannondale
    Last Post: 04-06-2011, 06:24 PM
  2. 2001 Jekyll 3000 crankset
    By aurtj2011 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2011, 12:04 AM
  3. Will a Nevegal 2.35 fit on a Jekyll rear wheel?
    By MrCrash in forum Cannondale
    Last Post: 10-13-2005, 04:50 AM
  4. used value of 2001 Jekyll 3000
    By herby in forum Cannondale
    Last Post: 05-06-2005, 09:07 AM
  5. 2001 Jekyll Rear Triangle Shot??
    By Luther in forum General Discussion
    Last Post: 08-29-2004, 11:01 AM
