Results 1 to 3 of 3
    2001 F700 Headshok Max Air PSI limit???
    im running 150 lbs in it now...what is the limiit so i dont blow anything? ild like it a bit stiffer....thanks... 6' 220#
    not sure what the limit is, but if you go to the cannondale website, they have a chart w/ reccomended psi's for the shock. I assume we're talking about the ultra fatty fork? Great frk I've got one on my F600. Just google reccomended psi's for super ultra fatty shock, and that should give you a link.
    Reputation: dascro's Avatar
    I believe the limit is either 200 or 225psi. Cannondale recommends you to run the 75% of your body weight in pressure. So in your case i'd try 165 psi.
