Results 1 to 12 of 12
    2.25 Stroke Shock on Prophet?
    I'm looking for a used shock for my Prophet and found one that is a really good price but it has a 2.25 stroke length rather than a 2.0 stroke length, how much would that effect, would I bottom on my seattube or would the bike ride really different?
    Feb 2007
    Quote Originally Posted by galbraithrider
    More importantly, you will have some serious clearance issues between your swing-arm and seat tube. I considered this myself, as I wanted a bit more suspension travel out of the rear, which was unnecessary anywhere. There is only one size shock to work on the Prophet...7.875x2". It's only good deal if it works!
    Yes the 2.25 stroke will fit. That's what I have on my Prophet. You can only use the XC setting to prevent tire to seattube contact. Using the FR will cause contact of the seattube. Yes you can feel travel especially on drops. Travel goes from 145 to 159.
    Hey Racerzero, What size fork do you run or your prophet with the 2.25 stroke shock in the rear. I'm kind of interested in the head angle and bottom bracket height? How hard are you pushing your prophet, I ride all mountain freeride lite (no more than 6 foot drops to tranny) and I don't want to break my prophet, just picked it up a month ago...
    Dec 2004
    Are you getting an air shock or coil?
    If you're getting a coil shock, you still have that bottom out bumper which no matter how hard you compress it, you're not going to get the full 2.25" stroke. So you might be safe.
    Worse case scenario, add a little spacer under the bumper to reduce the stroke of the shock.
    Intense 951 Evo and Intense Carbine 29
    Sadly the shock sold so back to searching. I am looking to replace my swinger air with a coil of some sort. I'm thinking either dhx 5.0 or roco. If I can't find a used one that will fit and have to buy new then I'm getting a dhx air. Just looking for a little more plush in the rough stuff to hold me over until I can get my perp...
    I run a Fox 32 so the headangle and BB height is basically stock. I own a Gemini and a Judge so there no reason to do crazy stuff on the my Prophet. The extra .25 just makes the bike plusher than normal.
    I have bottomed out the air shock with no contact issues.
    Remember the shock length is the same so there are no geometry issues. The extra stroke of .25 adds another 20mm of travel.
    Dec 2004
    I have a 2.25 stroke 5th Element on the way. I'll post pics of it in the FR position with spring off and compressed all the way. I'll take pics of the swingarm clearance. I'll put as much weight as possible to compress the bumper as much as possible too.
    Sweet, I was thinking of getting one of those but they are all gone now. Please post pics when you get it all set up. Thanks!
    Reputation: beavola's Avatar
    you'd invalidate your frame warranty for sure!
    Its a used frame so I don't have any warranty anyway. I think I'm just going to get a perp and leave the prophet for all mountain/cross country use...
    THELAND photographer
    Reputation: CdaleProph6's Avatar
    ... and if we just ...
    Quote Originally Posted by beavola
    agreed....stupid choice...ive seen it alot and although cool its not the greatest idea....
    want more travel
    sell the prophet and get a longer travel bike dont try to make it into something its not its like when your a kid trying to put a square block into a circle hole on that thing where you match shapes.
