Results 1 to 8 of 8
    change is good
    Sep 2004
    12' Lefty XLR vs Pike re: stiffness
    I have a Lefty on the front of my 429 and it is a fine fork. However, I was impressed with the stiffness of a Fox 34 and it subjectively felt stiffer than my Lefty. I expect the Pike to be as stiff as the 34. Are there others with similar observations?
    Nor­wegr
    Reputation: Vegard's Avatar
    Unless you tried the forks with the same wheelset that could attribute to some of the perceived flex.
    change is good
    Sep 2004
    Good point. My front wheel has been retensioned since riding the Fox and the front does feel tighter.
    Reputation: MarinCRO's Avatar
    Jul 2013
    Well, pike is a burlier fork and significantly heavier with longer travel, no?
    I'd say that better comparison would be Supermax.
    change is good
    Sep 2004
    I rode a Trigger with a Supermax in a parking lot and repeatly hit curb bumpers at slow speeds and struck them at an angle which would put on the ground with a lesser fork. The Supermax is amazingly stiff, but with an AC at about 536 I worry about slackening the bike too much and having too much of difference between travel front and rear.
    Jul 2013
    But isn't the Pike like 140-150mm fork, even on 29er?
    That would put it's ATC higher than the Supermax.
    I'm not sure if supermax can be lowered, but I don't see a point in a big, burly fork of around 100mm travel, for a more XC oriented bike.
    Surely, the regular lefty is plenty strong and stiff, or any other regular 100mm fork.
    Nor­wegr
    Quote Originally Posted by hellari View Post
    Yes, 29" Pikes are 140 or 150mm. They're available with 46(?)mm and 51mm offsets.
    I have a pike and a xlr lefty, but I don't think they can be compared head to head without alot of personal opinion.
    change is good
    Sep 2004
    I'm chunky and I like to ride in the chunk. The 429 is a capable short travel trail bike. The Pike can be lowered to 120. One of the Spec Cambers comes with it. The Supermax can't be lowered without modding it.
  1. 429c - Supermax vs Pike vs Lefty
    By DrDon in forum Pivot Cycles
    Last Post: 11-29-2013, 04:34 PM
  2. Replies: 12
    Last Post: 04-25-2013, 04:07 PM
  3. fork stiffness...
    By cunningstunts in forum Shocks and Suspension
    Last Post: 04-25-2013, 09:54 AM
  4. Fox 36 vs. Fox 34 - Stiffness
    By in the trees in forum Shocks and Suspension
    Last Post: 09-29-2012, 05:55 AM
  5. Highball stiffness?
    By powpow in forum Santa Cruz
    Last Post: 05-30-2012, 09:11 AM
